Question about Kenmore Refrigerators
Eite side by side with water dispenser in door. When push a glass into the water dispenser the water does not stop coming out unless we turn power off.
  • 262 Answers
If you had to shut off the water to make it quite then the first step is to disconnect the power to the water valve both of the power lines going to the double valve. then turn the water back on and see if the the water still comes out, if it does then the valve is bad and will need to be replaced. if it does not come out then you have an electrical problem, could be the switch or a controlboard or a short.
Posted on Sep 02, 2010
Water or ice from door will not shut off
You will need to replace the dispenser control pad. Here is that part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Frigidaire FRS3R5EMB Side by Side...
Door water dispensor stopped working, ice side is working fine. Water side used to click when placing a glass against the actuator so I am guessing a switch has broken - where is the switch located/ can it...
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Apr 26, 2010 | KitchenAid Superba Architect KSCS25INSS...
Hi The ice and water dispenser stopped working.
The first thing I would check is the plug eather under the plastic hinge cap on top of the door hinge or behind the grill at the bottom hinge to see if it hasn't come loose.
I would check to see if when you push the switch if there is current going to the water inlet valve located at the rear of the frig.
Shut the water off for the frig and disconect the line from the water inlet valve. Put the end of the hose into a pail and turn it on to see if you have good water flow to the valve.
If you have current (120 Volts) at the valve and still no water going through the valve, replace the inlet valve.
Dec 29, 2009 | Refrigerators
I have a side by side refrigertor and the water dispenser stopped working while I was filling a glass of water and I can't get it to come on
either a bad switch or water valve/relay. Follow the water line to the valves and then test for power when the switch is held down. If there's power, replace the valve. If not, replace the switch
Sep 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking through ice maker
check out the temperature inside of the freezer your probebl going to have to clean the condenser coiul underneith the unit
May 23, 2009 | Whirlpool ES5FHAXS Side by Side...
No ice or water from in-door dispenser
When you first hook water up to the refrigerator you have to fill a tank in the fridge. Open the water supply behind the ref. turn the control on the front of the ref to water and hold a glass under the spout as if you are filling a glass . You may have to wait 3-4 minutes forthe tank and lines to fill with water before you get any to come out into the glass. The water my be discolored at first so run a few glass full through before drinking . hope this helps
Bobalix
Apr 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a jsd2789ges jenn air water dispenser not working at all
hi there,
sounds like you have an icemaker problem. i would recommend replacing it.
Oct 02, 2008 | Jenn-Air JSD2789GES Side by Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
48 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
