Question about JVC Everio GZ-MG465 Hard Drive Camcorder
My JVC MG 465 suddenly stopped working. No power AC or DC and of course does not charge. Possible problem. It is 18 months old and hardly used. Np power means cannot reset to Factory settings
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 03, 2010
My iPhone 4 is a few months old and last night it suddenly stopped charging. Of course i didn't realize it until my phone died during the day today and i tried plugging it in and wouldn't ch
The charge adapter maybe faulty.
If your cell phone is a few months old, then it would be still under warranty. Take it back to the place where you purchased it and have it repaired or replaced under warranty.
Jul 26, 2012 | Apple iPhone Smartphone
Plantronics cs50 red power light is not lit
Sorry to hear about your bad luck there. If a hard reset does not work and its not simply the power button is not correctly aligned (try fiddling the pressure up and down if it is loose) then it's likely the device has failed. Even though it's survived other power outages it's still entirely possible the most recent one has caused this failure. I've seen failure of electronics from operating on unstable voltages from solar panels and less than perfect inverter systems and it's always the case that "it's been working fine up until now!"
Mar 01, 2017 | Plantronics Radio Communications
Emerson PL-P42W-10A Loud pop, then no power, AC power okTV is about 18 months old. While watching I heard a pop and now TV shows no indication of power. Checked AC, OK.Im guessing a power supply
Power supply is most likely but best way is to with a volt meter follow the voltage to see if have in and out of the power board.
IN will be AC and output will be various DC voltages.
Jun 12, 2012 | Televison & Video
The window is suddenly shutting down everytime i open it, eventhough it is fully charged?
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 25, 2011 | HP Pavilion dv6000z Notebook
Acer Aspire 7741Z - 4643 that is only 2 month old. It is plugged in, and recognizes that it is plugged in, but does NOT charge the battery. Please let me know what to do. Thanks, Not charging
Hope this will help...Your response is very much appreciated...
Feb 06, 2011 | Acer Aspire One PC Notebook
I have a es8000 and it has been a good unit. It all of a sudden stopped charging while it was running under a very small load.how and what do I check first.Paramac es8000
This likely has a diode module which rectifies a low voltage AC winding to do the charging.
Things to check: There USUALLY is a fuse on the low voltage winding. It SOMETIMES is within the generator covering.
Check for loose connections or broken wires.
The diode module is usually a 25 amp block about 1.25 inches square with 4 faston terminal connections.
Use a meter set to AC to check voltage on the AC terminals... might be around 18 volts or so.
Then on the DC terminals labeled + and - with meter set to DC.
To charge a 12 volt battery there needs to be about 13.75 volts or so.
Mar 31, 2010 | Pramac Electrical Supplies
My laptop stop charging.
Batteries get old and wear out. Be use AC outlet is working. Check for power light on AC/DC charger box between laptop and AC.
It is common for Laptop charging/power connectors to get worn and/or loose(intermittent). Try to get charging light on PC by wiggling power connection to PC.
If not, if you have a VoltOhmMeter(VOM). check for 5V on barrel power connector on the charger side, that plugs into PC, Outside conductor is GND and Inner connector is (+5V). VOMs are cheap at RadioShack or AutoParts stores and are a handy tool to have around the house. Book shows you how to measure. PC is 120V AC on Wall side of PC Power Supply from Wall Outlet, and 5V DC on PC side of Charger.
Charger may be defective. Cheap on Ebay.
Feb 23, 2009 | Acer Aspire 3680 Laptop
Converting dc to ac
You need a DC power supply of at least 8 amps (20 would be better). Try MCM: http://www.mcminone.com/product.asp?product_id=28-8945&catalog_name=MCMProducts
Sep 22, 2007 | JVC KD-SX980 CD Player
JVC Everio GZ-MG465 Hard Drive Camcorder Logo
139 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
