Question about Dell P703w Printer
The panel on the printer says the printhead is missing, not installed correctly, or has come loose. We changed the print cartridges last week (with Dell brand) and the printer worked that day, but is giving me an error message today. I have taken theh print cartridges out and back in half a dozen times, but can't get rid of the message. I did have to gently tug on the guide cable to get the print head to the center of the printer
SOURCE: cartridge error
I switched my cartridges, color in black and vice versa, then printed test page then switched them back and they worked fine.
Posted on Dec 21, 2007
SOURCE: dell photo 924 ink cartridge problems
Same problem I am having. Replaced 2x. Clean the contacts with alcohol, if that does not does trash the unit and get a HP where you can go anywhere for ink.I read all over that these are bad units.
Posted on Jan 16, 2008
Maanita
  • 1142 Answers
SOURCE: Dell 810 giving Incompatible Ink Cartridge error message
Hi try these steps
STEP: Disconnect and Reconnect the Printer Power Supply
Top of Form 1
Bottom of Form 1
Unplug the power cord from the wall socket.
Disconnect the power supply from the back of the printer.
Wait 15 seconds.
Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket
STEP: Clean the Contacts and Wick the Ink Cartridge
Ensure the printer is powered on.
Lift the scanner unit.
Open the cartridge latches and remove the cartridges from the carrier
Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back.
Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
Using a clean dry cloth, wipe the contacts so that no dust or other contaminants are visible
Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
Replace the cartridges in the carrier and close the scanner unit.
STEP: Verify Each Cartridge Carrier Has an Ink Cartridge
Check to make sure the left cartridge carrier contains a black or photo ink cartridge.
Check to make sure the right carrier contains a color ink cartridge.
Remove each cartridge and examine it to make sure the protective tape has been removed from the contacts and the print head.
Replace each cartridge in the proper carrier.
Let me know the status.
Regards
Posted on Feb 09, 2008
Ajkill
  • 2035 Answers
SOURCE: error problems wi Dell 626 all in one printer
Try these steps if this did not resolve try to clear the memory of the printer
and try to print ..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Feb 03, 2009
SOURCE: Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Posted on Jun 17, 2009
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Printhead Loose or missing. Install printhead or ink cartridges.
THE PRINT HEAD is the LASER that puts the image on the drum which puts the image on the transfer belt then paper or the drum puts on the paper. Missing the Print Head !!!!!!!!!!!!!!!!!!!! did you get it second hand? Not something you can get at a store. Contact the company and see about it being repaired.
Nov 15, 2015 | Kodak Esp 2150se Wireless Office...
I have changed out my black ink cartridge and now it says Attention: Print head loose, missing or not installed correctly.
Had exactly the same issue - working fine until ink cartridge changed (kodak for kodak - not a copy). Then can only get 'print head error message'.
Multiple attempts to remove and re-install, power on/off etc. but can't shift the error message. New print head more expensive than a new printer!
May 06, 2015 | Kodak Office Hero 6.1 All-in-One WiFi...
Cannot prink anything in black from my HP officejet 6500, have changed cartridge, colour print all ok
Check whether the cartridge's correctly installed and re-install correctly.
Clean the printhead by:-
  • Load into the printers paper tray a plain A4 sized paper.
  • On the printers control panel,press the setup button.
  • Select tools and press OK.
  • Now select clean printhead and press OK.
  • After printhead cleaning,turn the printer off and then on again.
Hope this helps.Thanks!
Oct 10, 2011 | HP Officejet 6500 Wireless All-in-One...
Printhead missing messag
you must be change printer head or reset
Sep 05, 2009 | Kodak ESP 5 Printer
Kodak esp 5 all in one printer, in the box where you read the info it says, error- Printhead missing, not installed correctly or has come loose. Checked all of that and it is still telling us this. What is...
switch off the printer again switch it on after 1 minute.. open the front access door , remove the ink cartridges and remove the printhead. reseat printhead properly until u hear a click sound. then again insert ink cartridges and wait for 2 minutes. go 2 menu and press caliberate printer.it will print a caliberation sheet. and now try to print ur doucment
Jun 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error message: Printhead missing, not installed correctly or has come loose
In regards to the error message with the printhead missing or come loose......I had that issue just shortly after I installed my printer. I was going crazy trying to fix it taking it out and reinstalling which was a pain, removing the cartridges and then the printhead to no avail. Finally I got smart and disconnected the power cord from the printer itself, not directly from the outlet. Once I did that and turned the printer back on the error was gone. It might have been a fluke, but it worked for me, so you might want to try it.
Jul 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Dell P703w Printer Logo
69 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
