Where can I locate my filter
When I use my Indesit W1121 my clothes are still got hair etc on them, I have been told to clean my filter but I dont know where it is? please can someone help me?
    President:
  • 1,294 Answers
Plug off the wall first. A broad hose comes from under your tub, it leads to your filter; find where u can hv access to it.
Posted on May 10, 2008
My dryer leaves hair behind in my clothes
Hello Sanya;
My name is peter. I am a retired field service appliance technician.
You have one of two or both problems.
1.) Restricted air flow - If you do not have the high air flow to remove the hair you may be plugged up with lint. In the back of your dryer is a hot air distribution manifold. This is easily removed by several screws. Usually the bottom smaller port get plugged up and needs to be cleaned out.
The other item is the moisture sensor. It may be bad not drying the clothing enough for the hair to break free. This is located in side the front. You will have to remove both the top and front of your unit to access.
Jan 30, 2015 | Whirlpool GEW9250 Electric Dryer
My indesit WIB111 is full of water & clothes. how can I manually drain the water out?
put the machine in the emergency drain mode press the start button when it stops
http://www.manualslib.com/manual/76755/Indesit-Wib-111.html?page=13#manual
Dec 12, 2014 | Indesit Washing Machines
My WD 12X machine is not drying the clothes. They get hot but not dry. Is there a filter somewhere that needs to be cleaned?
Presuming that this is an Indesit WD12X.
Yes, there is a filter at the bottom left of the machine (It can be clearly seen in the illistration on Page 14 of the manual, figure 6).
If you don't have a manual, you can download a PDF of it here:
http://www.indesit.co.uk/indesit/_pdf/manuals/19503326500_UK-USA-AUS.pdf
It's highly likely that the water isn't getting evacuated because the filter is blocked and so there is just too much water to dry. Unscrew the filter, clean and replace. I'm amazed to discover that (so far as I can see) The manual never even mentions the filter! Well done Indesit
Jul 19, 2011 | Washing Machines
My Dyson Animal vacuum smells horribly of dog. It's worse than my dog has ever smelled - even at his worst. How do I take apart the Animal to clean it properly? Can I use a weak water/Chlorox solution...
hi Donna.
Complete removal of pet hair from the home is a quandary many pet owners face. The Dyson Animal series vacuums use centrifugal force to remove animal hair from carpets, floors, curtains and upholstery. The high-powered vacuum is bagless, allowing you to extract pet hair from surfaces without worrying about running out of vacuum bags. As your Dyson Animal vacuum is exposed to pet hair and dander, a smell can develop. Similar to other small appliances, a vacuum needs periodic cleaning to keep it looking and smelling clean. When you use basic cleaning and deodorizing techniques, you can get the smell out of your Dyson Animal vacuum.
Step 1
Remove the bagless receptacle for pet hair according to the directions provided for your Dyson Animal vacuum. Hold the receptacle upside down inside a trash bag and tap the bottom to remove pet hair and dirt.
Step 2
Mix 1/2 tsp. of dishwashing detergent with 1/2 gallon of warm water in a bucket. Dip a clean cloth into the soap solution and wring it out.
Step 3
Wash the inside and outside of the receptacle with the cloth to remove dirt and dander that cause odor. Rinse the receptacle with a cloth dampened with water. Dry it thoroughly with another cloth.
Step 4
Remove the HEPA filter from your Dyson Animal vacuum. Pick visible clumps of pet hair off the filter and discard them. Flush the filter with cool water to wash out dirt and hair. Rinse the filter until the water runs clean. Gently squeeze the filter and allow it to air-dry for up to 12 hours to ensure it dries completely.
Step 5
Moisten a cloth with undiluted vinegar. Wipe off the exterior of the vacuum with the vinegar. Deodorize the receptacle and interior areas, where the bagless receptacle and filter go, by wiping them with the vinegar-moistened cloth. Dry the vacuum with a clean cloth.
Step 6
Place two drops of vanilla extract on a cotton ball. Drop the cotton ball into the receptacle before securing it to the vacuum to prevent odor from building up. Vanilla extract is an effective natural odor absorber.
hope this helps you out.
Nov 28, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
Draining but nothing else
This is a really common problem that most people send hundreds when they can fix it themselves. Power off your washer, put it on its side. Your going to see four to six silver bolts with hex heads located in the center holding in a plastic device known as the filter assembly. Remove the screws and find any hair inside the assembly. Remove the hair and put the screws back in. Even the smallest amount of hair inside the filter/drain assembly will cause this problem.
Jan 22, 2011 | Indesit W 123 Front Load Washer
Dog hair remains on clothes/blankets after washing
if you want suggested answers you have to provide make, model and type of washer ( top/or front load )
if it is a westinghouse , simpson, hoover or like make top loader , there is a lint catcher bag at the end of the center spindle cover that you simply pull up and unclip and turn inside out to clean
Soe put the detergent in that cover for the washing
Mar 18, 2017 | Kenmore Washing Machines
Indesit WG1234T - is there a filter and spin cycle not effective
If there is no filter located at the bottom right front of washer behind a re- moveable cover, then you need to remove the rear cover of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should help solve your prob.
Jan 05, 2010 | Indesit W 123 Front Load Washer
Washing machine
did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Aug 16, 2008 | Indesit W 123 Front Load Washer
Wil133 indesit 1300 washer dryer
look for debris in the filter,
remove the bottom front panel ( 3 screws on bottom)
Unplug washer ,
open the large access filter screw on in center , be ready for excess water to spill on floor, clean filter and be sure the pump impellers spin freely.
Feb 25, 2008 | Indesit W 123 Front Load Washer
Indesit IDL 730
as you have checked that all the filters are clean this could mean you could have a problem with your pressure switch. This is a small round device that tells the washer that there is enough water in it . The pressure switch is located under the washer and is eay to fit . Once you have taken off the base of the dishwasher you will see a small round thing attached to the side of the washer base . It has a block connector and a small tube connected to it just remove these two and replace the switch and re plug it in
Dec 11, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Washing Machines Logo
109 people viewed this question
Top Washing Machines Experts
