Question about Kenmore Ovens
The oven door is locked. How do I unlock it?
    Problem Solver:
  • 11 Answers
You can try holding the clean button until it unlocks (varies with version)... Otherwise accessing from the back and manual manipulating the locking motor is another option.
Posted on Sep 02, 2010
Door lock is on but door is not shut, how do I get it unlocked so door can go shut
Unplug the oven for 5 minutes and see if the lock resets.
Nov 22, 2016 | Ovens
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    How to unlock the hinge on an Ariston Oven Door with door off
    To Unlock the hinge on an Ariston Oven Door
    Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you.
    With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over.
    Fitting the Oven Door
    Fit the door to the oven with the metal receivers in the slots on the oven.
    Once the receivers are in the slot, fully open the door (in a downward position).
    Flip the U shaped pieces over to lock the hinges.
    May 17, 2010 | Ovens
    Oven door is locked and won't open
    oven door locked during cleaning then would not unlock after cooling
    Jan 19, 2010 | GE JKP86 Electric Double Oven
    How do you unlock the door to a convection oven?
    Here is what you do when the convection oven door locks automatically. Where the stop/clear button is, you will see a lock symbol that has a number 3 on it. hold the stop/clear button down for 5 seconds and it will unlock you convection oven.
    Nov 18, 2009 | Kenmore Ovens
    I CAN'T UNLOCK MY OVEN DOOR!
    First get rid of the noise by turnining off te breaker.
    You will have to pry the lock open.
    This is common I use a small screwdriver and coathanger wire,then pull out oven enouhg to replace lock.
    Mar 12, 2009 | Ovens
    My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
    Control panel and oven door lock
    The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
    To lock the control panel and both oven doors:
    1. Press and release Cancel.
    2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
    To unlock the control panel and both oven doors:
    1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
    Dec 22, 2008 | Jenn-Air Electric Double Oven
    Oven Door Locked
    the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
    Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Ovens Logo
    70 people viewed this question
    Top Kenmore Ovens Experts
    Dan Webster
    Dan Webster
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
