Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Starts ok but when accelerating, it stalls out. I think it needs a diaprahm/rebuilt kit for the caruretor?
  • Troy Master
  • 7,482 Answers
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
MY HONDA 3000 IS GENERATOR KEEPS STALLING OUT, BUT IT ALWAYS STARTS UP IMMEDIATELY FOR ME, COULD IT BE OVERHEATING?
No, as with most small equipment engines, the culprit is the carburetor. You'll need to soak it in carb cleaner overnight in a sea;ed container and install the rebuilt kit for it.
Jun 16, 2015 | Honda 3000 Watt Portable Generator
Starts and runs, stalls out. rebuilt carb same problem??
at what point does it stall out? when you try to go to full throttle or while it is just idling?
Feb 13, 2013 | Craftsman Snow Blower / Snowblower Bottom...
Boat starts fine runs idle fine, accelerate no
make sure that the timing advance mechanism in the distributor is working freely.
Sep 30, 2009 | 1984 Chevrolet Chevy
2001 2.4 automatic. problen is when put into gear
check tranny fluid if its ok,tranny need rebuilt.sorry.
Jun 05, 2009 | 2001 Pontiac Sunfire
The car starts OK. When driving, sometimes the engine stalls and suddenly starts again and starts accelerating at the same time.
Before you tear apart and replace the whole car like I did, you have THREE converters on that car. The front two are part of the y-pipe and one on center pipe. Vacuum check when hot or look under it in the dark after running about twenty minutes, any glowing red in converter. you need to clean or replace. vinegar and distilled water soaking, it can be done, will help clean the y-pipe one, the other is 75 bucks aftermarket and worth the change.
May 20, 2009 | 1987 Chrysler Fifth Avenue
Choking and stalling while running and then will not start
Might be dirty fuel filter change the fuel filter see how it runs.
Nov 18, 2008 | 1988 Oldsmobile Cutlass Supreme
96 GMC Vandura idle problem and sometimes acceleration problem
accelerator pedal position sensor/ throttle position sensor/ motor
idle problem under load could be idle rpms too low
ICT sensor
run the fault codes
Apr 24, 2017 | GMC Vandura Cars & Trucks
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
578 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
