Question about Metra Ford F 150 Truck 1999
I replaced my starter & my solenoid & my truck still won't start
  • randylancon Sep 03, 2010
    I tried this solution but, it didn't work ,someone told me that the chip in my key could have gone bad , do you think this may be causing the problem?
    Master:
  • 373 Answers
Try replacing the battery cable ends especially if tey are the sealed lead type
Posted on Sep 02, 2010
I have a spider box yerfdog 3206 wt i believe 150cc howhit engine. Won't start solenoid clicks but no power to starter. even direct power to starter wt solenoid bypassed starter won't kick in ? I have
this sounds like the starter is no good that`s why you get a click noise and why bypassing the solenoid it won`t turn over. the armature must be drawing more amps than what can be supplied.
Sep 21, 2014 | Cars & Trucks
Vw super beetle won't start after sitting for a few days. After I arc the solenoid, it will work.
If you put battery voltage to the starter solenoid &
it works & the starter works,then the solenoid control
circuit has issues
Fuse,ignition switch,neutral safety switch,clutch sw
& such, depending on what the car has
You could try switching relays but doubt that is an issue
Mar 11, 2013 | Cars & Trucks
My 2008 silverado won't start battery is charged
No, it isn't an ignition issue.
Check power to the starter motor solenoid.
If this is getting power when cranking, then the issue is with the starter motor solenoid or starter motor. Replace.
Nov 12, 2012 | Cars & Trucks
Won't start
How about corroded battery cables (internal)
Fusible Link wiring corroded & open circuit,does
everything electrical work except the starting circuit?
Turn key & have power to starter solenoid ?
Neutral Switch !
Ignition Switch !
Tough to guess without wiring diagrams,
to see where to start testing
Can't fix what you don't know you have
Oct 02, 2012 | 1990 Ford F150
1966 mustang 289. won't start, jumped across solenoid, started. Replaced solenoid-starter wouldn't disengage, replaced starter, back to square 1, jumping across solenoid to start - whats my...
Ignition problem... No signal from ignition to solenoid...run a starter draw test to confirm starter is ok --- You can run your jump wires to a remote starter button or switch to get around it for now.
I hope this helps.
Sep 22, 2011 | Ford Mustang Cars & Trucks
94 cadillac won't start, even with a jump. Battery is new and inside lights do come on, but vehicle won't start. Any advice? Thanks
Check the starter/solenoid - sounds like either one or both need replacing. If you can get the starter off - you can take it to an Auto Zone or an O'Reilly's to get it tested. I'm not sure of any tests for the solenoid (sometimes it's part of the starter) - some cars also have a starter relay switch. If that's the problems - it's usually cheap & easy to replace.
Jul 01, 2011 | 1994 Cadillac DeVille
Solenoid starter problems
sometimes is better to replace the entire starter and not just the solenoid that way they are usually under a lifetime warranty and you can just exchange them. it does sound like you have gotten faulty solenoids though.
May 20, 2009 | 1991 Mercury Sable
Car won.t start makes a clicking sound
this is always the starter solenoid that does this, replace the starter solenoid.
Apr 12, 2009 | 1997 Saab 900
Metra Ford F 150 Truck 1999 Logo
20 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
