Question about Roper RGX4634KQ Gas Dryer
Roper RGX5634KQ2 Dryer will fire initially, and heat up. It will stay fired up for around 1-2 minutes, and go out. After another couple minutes, the igniter fires, but there is no flame. This continues throughout the dryer cycle, as it will not ignite. Does this sound like a Gas Valve Coil problem?
  • Roper Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Could be a coil...but I have learned that it usually is the ignitor...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 02, 2010
My roper dryer model rgx5634kq2 wont heat. the glow bar comes on and then goes off, other times the glow bar comes on and there is a flame, the timer only advances for certain cycles as well.
heatman101
Mar 08, 2011 | Roper RGX4634KQ Gas Dryer
Roper rgx5634kq2 gas dryer. Starts out lighting like it should. It runs for a minute or two then flame goes out, then after a minute it comes back on. It will do this cycle a few times and then it will...
it's not the thermal fuse,the dryer wouldn't run and the ignitor wouldn't glow.sounds like you have bad gas coils,if the dryer runs for the first 15 to 30 minutes normally and then no more flame the coils are failing,when they are bad they work until they heat up and then nothing,when they cool down they work again,common problem,also you should clean out the dryer once a year ,clean out the duct that the lint filter slides into,if your vent line is long take it off from the back of the dryer and blow it out with a leaf blower,make sure the outside vent is clear first,you can have a fire and then you can pop the thermal fuse,clean it and your clothes will dry on time,let me know what you find
Aug 25, 2010 | Dryers
My gas dryer the heat cycles on & off
clothes not drying, but dryer runs & heats?
1.defective thermostat-----replace
2.fan or it's pully loose on shaft----tighten set screw
3.incorrect heat or timer setting---reset timer
4.clothes to wet to when placed in machine
5.clogged lint screen or duct---clean out
Jul 29, 2010 | Roper RGS7646KQ Gas Dryer
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Roper Dryers
I have a roper dryer rgx5634kq2 ran out of gas tried it when gas refilled the dryer pops breakers and wont turn on
Check all your connections. Must be a loose wire somewhere.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 21, 2009 | Roper Dryers
My dryer turns on and heat fires up but only stays on for about ten min then shuts off Roper rgx5634kq2
the coils may be weak and not holding the valve open for the gas or you may have a weak ignitor. the ignitor should glow white hot not orange. hope this helps.
Oct 15, 2009 | Dryers
Neptune Gas dryer burner will not continue to fire
There's a good chance you need to replace the igniter. Careful, they are brittle !!!
Sep 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My dyer works but does not heat i put a innighter in already
most likely need to replace the heating coil which is probably cracked or broken
Mar 12, 2009 | Roper REX4634KQ Electric Dryer
Dryer wont get hot in the am i try it it will wrk for one load then wont get hot same thing for 4 days now
I have a Whirlpool dryer with LP gas, 7 1/2 years old. It will fire up once or twice after started then the next time it is supposed to fire it will make a buzzing sound. No heat. It will not produce heat after this until it sits for awhile then the same thing, will fire once or twice then no more. I replaced the ignitor and this did not solve the problem although it did have a consistent firing for about 3 minutes immediately after I replaced the part. then it started buzzing again and would not fire anymore. The propane line doesn't appear to be the problem either since it will work initially. Also the gas water heater in the house works fine.
Sep 23, 2008 | Kenmore Dryers
Kenmore elite gas dryer won't fire up
replace the coils on burner valve ..they will fail sometimes after initial heat up both are in kit change both
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Roper RGX4634KQ Gas Dryer Logo
171 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
