No sound from my ps3 optical input - Audio Players & Recorders
  • 5 more comments
  • d_pease64 Jun 28, 2008
    Same thing, nomatter what I try, no solution online works for me. I think the reciever does not pick up the digital signal but i've tried in both slots, and on manual and auto search.
  • Anonymous Aug 16, 2008
    Me too! It's driving me mad.... any thoughts, anyone?
  • Anonymous Oct 04, 2008
    i have the same issue. Sometimes if I turn the receiver and the PS3 off several times it starts to work. But, I cannot figure out what is causing this to happend.
  • Anonymous Oct 08, 2008
    I got it also, anyone figure it out yet, becasue its making me mad.
  • mmullens Jan 03, 2009
    Same problem, my cable box works through the HDMI + TV/SAT optical audio port, but my PS3 audio won't. The PS3 video works though...weird? Please help before I smash this thing!!!
  • twiddle88 Jan 26, 2009
    No sound from my ps3 over optical cable, too .Coax from DVD player works fine.
  • jj000 Mar 30, 2009
    Ok so I have a pair of AX51 pro headphones.
    I've changed the audio settings on my ps3 to optical out/ dolby 5.1.....
    but no sound....yet when I plug em into my mates ps3 with the same settings....they work fine.
The axpro is for the ps3 and xbox 360 and also the pc but the ax51 pro is made best for pc gaming...if you noticed the ax51 comes witth the cables for your pc and the axpros come with every cable for xbox and ps3..i have both the axpro and ax51 pro....
Posted on Feb 28, 2010
Tried everything also...same as you two...nothing.
Posted on Sep 06, 2008
Onkyo ht r508 amp is not able to receive audio signal from ps3 through optical out
Have you assigned the optical input to the input you are attempting to use? Scroll through all inputs and you may find the sound is there. If not check the optical cable is working (red visible light) Also a big one is making sure in your ps3 settings that the setting for audio out is set to 'optical'
Mar 01, 2014 | Audio Players & Recorders
Ps3 doesnt give out a surround sound output
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
NO OPTICAL SOUND I connected HDMI from reciever to TV, HDMI from PS3 to TV, Optical from PS3 to Receiver (PS3 Sound settings switched to Optical, with Dolby Digital 5.1CH, and Dolby DTS 5.1 selected) ...
I think your problem might be at the digital audio setup at the receiver. To fix this, go into the setup under digital audio and make sure that the input that your connected to is set to optical, not analog or coaxial. Example if your plugged into video 1, make sure that the audio setting corresponds to the optical input where your connected. Video 1-optical-1.
Good Luck
Jan 07, 2011 | Samsung HTC5500 Theater System
Surround sound on ps3
Most digital inputs are assignable, so go to set-up menu on your receiver and make sure the optical port (opt1 , opt2, etc.) is assigned to the input (vcr, aux, etc.) that you want switch to to listen to the PS3. You may also need to go into the PS3 settings menu and turn the optical to output the Dolby Digital signal. You have to do this with most DVD players, too.
Jun 13, 2010 | Sony Playstation 3 (PS3) Console
I used an optical cable from my ps3 to my receiver but no sound
change the sound output to 'optical' on your ps3
system menu
Sound
Sound output
(select optical)
I think you may have to change the channel on your AV reciever to Input or audio or something
Jul 08, 2009 | Audio Players & Recorders
How do i hook up a PS3 through my denon avr1905?
ONCE YOU CONNECT THE OPTICAL CABLE AT THE DENON, YOU ALSO NEED TO CHECK THE AUDIO SETTING FOR THE INPUT USED AND MAKE SURE OPTICAL IS SELECTED AND LAST ONCE YOU SELECT THE SOURCE INPUT USED TO CONNECT THE PS3 TO THE DENON PRESS THE INPUT MODE BUTTON ON THE FRONT LEFT OF THE DENON UNTIL YOU SEE DISPLAYED THE WORD AUTO, THIS SHOULD GET YOU SOUND AS LOND AS THE PS3 IS OUTPUTING AUDIO OVER THE OPTICAL
Mar 01, 2009 | Denon AVR-1905 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
RCA 2280 Optical Input w/PS3
The only optical option is through the satalite function. After I hooked up my xbox 360 with optical audio, I pushed the SAT button on the front of the RCA receiver then turned the multi jog wheel until it read "optical" out came surround sound. I hope this helps you.
Dec 07, 2008 | RCA RT2280 System
Problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Dec 01, 2008 | Yamaha RX-V461 AV Receiver
Audio decoding
You will need to tell the PS3 to use the optical cable for digital output in its setup, as well as tell your amp to use the optical cable as the input for whichever 'source' you wish to have associated with the PS3.
Nov 22, 2008 | Sony Playstation 3 (PS3) Console
716 people viewed this question
 Grubhead
Grubhead
