Question about GE Heating & Cooling
I have a GE AEH25DLH1 The Display says "EP" What is this and how can I get into the Cool mode?
3 Suggested Answers
vetteman3002
  • 2299 Answers
SOURCE: I have a A/C unit
I just had the same happen. I called everyone up to GE and GE couldn't give me an answer. I finally found a repair shop that had seen the same error. It is the result of a failed sensor on the cold side coils. I think it is basically a thermocouple. My particular unit (Model AEH25DLH1) has two thermocouples; one for the temperature reading on the display and one to signal the electronics in the event of the cold side coil freezing. This is the one connected to the copper portion of the tube part of the cooling coils. The local shop put a thermocouple (display thermocouple) from another unit in place of the cold side coil thermocouple. We basically bypassed the one that triggered the electronics in the even of the coil freezing. You can't just buy the thermocouple from GE, you have to buy the whole computer board which is about 100 bucks... The reality is the thermocouple is what is bad and if you knew the specs of the thermocouple, you could replace it for around 10 bucks probably... Makes me want to not buy GE products any longer... My units was about 2.5 years old. Check with your local appliance repair place to see if they have any old units that may have the thermocouple you need and hopefully you can save a few bucks... I hope this helps...
Posted on Oct 18, 2010
  • 3 Answers
SOURCE: EP Message - no cool air on a GE Air Conditioner
I just posted this on another one, but try unplugging it and pushing the reset buttons on the side of the plug. It worked to fix mine so far...
Posted on Oct 19, 2009
My ge AEW18DMG1 window unit shows an error code EP. What does it mean?
GE EP code is main compressor sensor.
Check damage to the temperature sensor
Sensor Cable left side yellow.
My airco got visited by a rat and damaged the wiring.
Cut it rejoined and code 32 changed into temperature.
You need the sensor. Just joining the cables will issue 99 and it will cut off and change into 32
You need a working sensor.
Jun 01, 2012 | GE Air Conditioner Main PCB - WJ26X10241
I have an GE air conditioner with ''EP error code, and compressor stops.
Jul 01, 2010 | GE Heating & Cooling
I am trying to record a program in EP mode but when it records it returns back to SP mode. How can I set the tape for EP without it returning to SP?
Most VCR's have a default recording setting for recording speed or other settings. It's just a question of finding the right menu. Have a good look around the menus. However the VCR might default to SP after recording in EP, however the playback should switch to EP when playing.
Jun 09, 2010 | Televison & Video
What does EP mean on the air conditioner display?
I had this same problem with mine, i unplugged it and pushed the reset button on the side and now it's working fine.
Aug 25, 2009 | GE Heating & Cooling
Jul 27, 2009 | GE Heating & Cooling
Recording from VHS to DVD
First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
Now it will play on other players.
Here is a link to the user manual:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
-Tha Mp3 Doctor
Dec 31, 2008 | JVC DR-MV7 DVD Recorder/VCR
I am recording fron VHS to DVD. When I am finished and push the stop button, How can I tell how much space is on the DVD to record something else and how do I finish the dik so it can't be recordered over
JVC DVD Recorder – Finalizing and disc space
-Tha Mp3 Doctor
GE side by side fridge not cooling, can't adjust temp control
Most likely it's not defrosting, many GE fridges need new defrost heaters every couple of years.
Jun 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
VHS Tape recording time mode
There should be either a switch or button on the front panel
that changes the display panel to reflect mode change
If not then If you have osd then you will have to change
speeds via the osd record mode or timer mode (if exist)
Nov 16, 2007 | Quasar VHQ401 VHS VCR
Heating & Cooling Logo
76 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
