Question about Amana ALW480DA Top Load Washer
When water fills up it will not agitate - Amana ALW480DA Top Load Washer
    Champion:
  • 245 Answers
This is a typical problem. What you have is a broken lid switch. This is either located on the door way of the washer or under the control panel. Not a difficult thing to change.
Posted on Sep 02, 2010
Agitating during water fill up
HI WHEN EVER THE AGITATOR WORKS WHILE FILLING THE TIMER IS FAULTY
May 03, 2014 | Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Kenmore 80 series top loader washing machine 110 volt was plugged bu mistake into 220 volt outlet. Machine will no longer fill water or agitate but when put into spinning it will spin
    First off I can tell you the water valve coils are probably cooked / burned out. With POWER OFF / unit unplugged you can remove one wire from each of the coils and check for resistance across the coils. No resistance = open coil = no fill. NO FILL = no agitate because the water level pressure switch is trying to sense the water level that never rises. If there is no water then there will be no agitation.
    If you really want to see if it will agitate in it's current condition you can fill the unit with a garden hose on a low level water setting and fill it a little over half way to see if it will agitate. (You will have to remove the hose and close the lid)
    If that works then the water vavle would be the culprit causing your condition. The wire wound in the coil windings of the water valve is smaller in thickness than a human hair and would easily fail if 220VAC was put across a 110V winding.
    Feb 02, 2010 | Kenmore 24032\24036 Top Load Washer
    Agitator starts before water fills. When adjusting
    There may actually be more than one setting on the diaphragm control, or you may two diaphragms each with their own setting control. I hope this helps you! Good luck!
    Dec 29, 2009 | Washing Machines
    Agitator starts at begining of cycle before washer is full
    Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
    Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
    After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
    Quentin
    Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
    Washer functions but doesn't fill with water, with
    if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
    replace the water level/fill switch for the fix.
    Phil
    Jun 10, 2009 | Washing Machines
    Will fill water but agitator wont run.
    Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
    Hope this helped.Let me know by rating me
    For more help go to live chat.
    lenwest
    Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Water fill problem
    did you clean the screens in back of water valve? normally a fault code appears if it's a fill issue also the tub will spin at beginning of fill to soak clothes first before beginning to agitate
    Jul 17, 2008 | Whirlpool WTW6600SW Top Load
    Amana ALW480DA Top Load Washer Logo
    Top Amana Washing Machines Experts
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Terry Schneider
    Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
