Question about Clarion Car Audio & Video
I bought a used 6 disk changer cv919 to replace my bad unit in my 2002 se-r when the unit powered up it read err code 2 and won't work
  • dchasesr Sep 02, 2010
    there are no disk in player and it won't take in a disk
  • 22,156 Answers
Well something is wrong and it could be a jammed CD ,best advice i can give is to cut losses and fit an aftermarket radio with a usb and SD card player ,that way a 1gb SD card will hold and play 20 or more CDs .they cost about 80 euros here in spain and one with built in blue tooth about 120 euros .I do feel this is a cheaper alternative than messing around with cd changers that inveriably go wrong with age .
Posted on Sep 02, 2010
  • 503 Answers
out of focus. if all of your discs have the same error code, it is optical lens problem. have it checked to the nearest service center.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
Pioneer PD-M551 cd changer won't play cds 2 thru 6.
Thank you, Mark Z! My Pioneer PD-M551 would just stop reading the CD, usually near the end of the 4th or 5th disk, and then sometimes it wouldn't read any disks or maybe only the first one or two. I observed that the white ribbon cable was most contorted near near the end of the 4th through 6th disk (also discovered the disks are read proceeding from the center outward, unlike vinyl records). I unfolded the ribbon, massaged it and left it loose and unfolded and that fixed it (at least, temporarily). The PNP-1343 ribbon cable from Pioneer costs $11 but with shipping and handling it is over $30 so I haven't bought it yet.
Jan 28, 2012 | Pioneer Audio Players & Recorders
Hi i have a Honda Accord 2006 SE. It has a 6 disc CD changer and it had been working fine. Suddenly now i am seeing CR ERR message and CDs dont play anymore. Whenever i turn on the CD player it says CD...
Personally I would just replace the radio. In dash changers go bad easily and are basically just a problem waiting to happen. The average life span of an in dash changer is about two years.
Sep 15, 2011 | Car Audio & Video
HOW DO YOU GET THE CD CHANGER TO PLAY WHEN IT IS READING ERR
I don't think the cd changer mechanism is ok if it reads err continuously or with more than a few cd's.The lens may be dirty, but in many cases it may need a new cd-changer mechanism or another cd-changer altogether.
Oct 05, 2010 | 2002 Isuzu Rodeo
2000 jeep grand cherokee limited 10 disk cd changer says ''err''
The in-trunk units have a tendancy to go bad. you can take the cover plastic interior cover off to access the CD changer, un bolt the changer, and visualy inspect the two rollers for debris, or missing /broken gears that move the rollers to take the CD from the CD cartrage to the player. if that looks fine, chances are that the laser went bad (common in rear mount units) and you can order a new one from Jeep, or you can remove it and update the in-dash head to an aftermarket of your choice (& yes you steering wheel controls will still work). you could also fit a more modern MP3 unit where the Changer was.
Feb 20, 2010 | 2000 Jeep Grand Cherokee
Err message on 1999 Jeep Grand Cherokee 10 CD changer
I had a similar problem which responded to the use of a CD cleaner disc to clean the laser lens reading the CD. The "err" messages stopped and the changer started to work as it had before. Perhaps this will correct your problem too.
Aug 02, 2009 | Jeep AM/FM Cassette with CD Changer...
PIONEER CDX-FM65 PLEASE SCHEMATIC!!
err11 right? causes are either-
1/ dirty, scratched or upside down disk
2/ electrical or mechanical system fault
solution for number 2 from pioneer is
Turn the car ignition off and on again, or press power on/off button on the display unit and start the cd playing again
and one more thing to do is to open the door to the disk changer and bottom right you have a reset button press that then try again :)
These are the only thing err 11 can be with this model
Hope this helps you
Upfront Audio
Please rate and leave feedback thanks :)
Apr 17, 2009 | Pioneer CDX-FM657 6-Disc CD Changer
Sayes disk err can read disk
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
CLICK HERE TO ORDER YOUR NEW REPLACEMENT DRIVE(ROM)
Mar 21, 2009 | Capcom Resident Evil: Code Veronica X
Not sure what the problem is
Check the changer and see if cds are inserted correctly or if 2 cds are in one slot.
Dec 13, 2008 | Alpine CHAS-634 6-Disc CD Changer
Hi, My BOSE cd 6 changer was working fine on Sunday in my 2004 Mazda6. Yesterday however it wanted a code entering, which is odd because the battery has never been disconnected. I entered the correct 4...
The need to enter the code could be because of a brief loss of power to the unit, this could even be due to jump starting/ low battery power while starting or bad battery earth connection!
The err message is because you entered the wrong code more than once.......to get back to the screen to enter the correct code you will have to leave the power to the unit on for anything from half an hour to a few hours! But you will need to make sure you have the correct security code or you will block the radio and it can only be unlocked by an audio specialist and will probably cost more than the unit itself.
You can get the correct code for a small fee by contacting this link: Car radio codes in Uxbridge London Gumtree
Mar 24, 2017 | Car Audio & Video
Car Audio & Video Logo
74 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
