Question about Refrigerators
Refrigerator door does not stay closed. When the freezer door is closed the refrigerator pops open.
    Problem Solver:
  • 11 Answers
The fridge and freezer share their airspace, so when you close one there is a slight increase in pressure in the other unit. (Much like opening a window can cause a door open/close in your house due to pressure change/air movement) The magnet in your seal of the door is weak and unable to resist the pressure change. The seal should be changed.
Could also be that the door is not shutting properly in the first place due to sagging or skewed hinges that need adjustment/replacement and while shutting just may not be getting a complete seal that it should be.
Posted on Sep 02, 2010
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Freezer door opens when you shut the refrigerator door
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Sep 03, 2009 | Amana Refrigerators
Frigidaire FRT17G4BW9 doors not staying closed
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Side by side freezer door pops open
This is a problem inherent with lots of refrigerators. Side by side or top freezer. The rush of air pops the doors. You might want to adjust the pitch of the box by adjusting the front wheels to a higher level.
Jun 17, 2009 | Jenn-Air JCB2280HES Side by Side...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
How do you level the kitechenaid side by side
Hope this helps solve your problem, Let me know. Thanks, Sea Breeze
Feb 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
LG bottom freezer
Sounds like the refrigerator is sitting lopsided.  Make sure that the front legs are both retracted in the up position.  If it doesn't work, then lower the front leg on the hinge side of the refrigerator.  That will cause the frame to lift the door and it should be able to close properly.
Oct 25, 2007 | LG LRDN20720 Bottom Freezer Refrigerator
Refrigerators Logo
380 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
