Question about Campbell Hausfeld Air Tools & Compressors
One day I was useing A central Pneumatic Pancake #38898 Compressor. The next day it would not Run.
  • 22 Answers
Probably the switch assembly. check the red pull up switch . It may have melted at the hot line coming in causing a break in connection and break in power. This is most common when the compressor runs for extended periods of time without rest. Lots of luck.
Gill
Posted on Sep 10, 2010
Need fuse and cap for 3gal.pancake air compressor Model 60637
Jul 05, 2017 | Air Tools & Compressors
Central pneumatic 3gl pancake air compressor 61615 the reset button pops or blows wall socket fuse any ides why? motor brush replaced and new power cord plug put on the 3 grounding prong was cut off
most likely a start run capacitor has failed
do not remove any pins of a plug as they are all need for electricity
if the capacitor replacement makes no difference , get in an electrician to test the machine and insulation
Apr 19, 2017 | Air Tools & Compressors
Can I use another Central Pneumatic pump on my 61490 air compressor?
sure harbor freight tools sells new air compressor pumps, just be sure new one matches the R.P.M of the motor or I may damage it if it turns too fast of may not make enough air if it goes to slow , also be aware if belt pulley changes its diameter then pump speed will also change
Dec 05, 2015 | Air Tools & Compressors
I have a Central Pneumatic 38898 pancake compressor that will not shut off when the pressure reaches pre-set PSI. I have replaced the pressure switch but to no avail...HELP!!
There must be a blockage on the fitting where the pressure switch goes in that stops the air pressure from reaching the regulator. Try taking the switch off and turn the compressor on and see if air comes out the hole
May 23, 2015 | Air Tools & Compressors
Central pneumatic air comp model 9416797
Hi I have a central pneumatic 29gal 2hp comp when I turn it on it trips the breaker any answers
Sep 11, 2013 | Air Tools & Compressors
What oil to use in a #38898 central pneumatic 2hp pancake air compressor ?
You need to use a 30 weight NON-detergent oil. The important part is make sure it is non-detergent! You can usually find it at O'Reilly's auto parts and possible other auto parts stores.
http://www.oreillyauto.com/site/c/detail/PGD0/ND30.oap?ck=Search_non+detergent+oil_-1_-1&keyword=non+detergent+oil
Jul 18, 2011 | Garden
Air Tools & Compressors Logo
490 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
