Have a washer/dryer combo and it does not appear to fill. it does soak the clothes but i can not see the water level through the glass door and even when empty only seems to have a dribble of water in the machine. have checked all the filters and none are blocked. the machine showes no error message on the front.
    Genius:
  • 1,073 Answers
Check the fiil valve for a stopped up valve
Posted on May 11, 2008
I just bought a front load washer from a online yardsale,. My issue is when washing shouldn't it fill up with water to wash. Mine let's some water down, but clothes just flop around, no suds either,
They don't fill all the way, in fact they are hard to tell when they are filled because the water level does not rise to the level of the glass in the door.
Mar 11, 2016 | Washing Machines
Avanti W797 Combo Washer and Dryer............Does not fill with enough water to wash clothes. It will runn the cycles with some water, but clothes do not all even get wet????? How can I correct the...
I have this problem too. Called the repair man out to the house & he just told me it was set at the factory & there was nothing he could do. I discovered if I held the water level knob between the settings given, water would run to the level I wanted as long as I held it in place, but I don't know if this does any damage to the machine. So I don't know if you want to try that or if it can even be done on your model???
Feb 21, 2012 | Avanti W797 12 lbs. Top Loader Fully...
Uses to much water,fiils half way up the glass with water///and really uses alot of water on express wash
Set the washer with a low water level settting to confirm if the clothes are soaked in , if the water level does not go down it is possible that the water level pressure switch is faulty.
Sep 29, 2010 | Kenmore HE2 Plus Front Load Washer
Lg intello WD1243FH low water level? My Lg will not fill with water properly. It only lets in enough water to get the clothes wet then stops filling. I tried filling it manually through the drawer but as...
Try adjusting the water lvl going into the washer. Adjust accordingly. If you have a meter, just the resistance of the valves. Unplug of course. It should read about 1.4k ohms ish. Could be higher or lower but roughly that.
Apr 28, 2010 | LG Washing Machines
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Is it getting enough water?
For front loaders, they usually have the level underneath the door, they use small amounts of water, but they spin so all the clothes do get
soaked with water.
Feb 05, 2010 | Samsung WF317AAG Front Load Washer / Dryer
Siemens washing machine extremely low water level
This sound like a faulty water level switch. This is a diaphragm like device with a small clear plastic tube attached between the switch and the washer's outer tub. As water level increases, so does the pressure on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water and signals the timer to start the agitate cycle. Look for any obstructions in the tube and the switch can be tested for continuity using a multimeter. A lack of continuity indicates a faulty switch. Hope this helped and best wishes.
Aug 07, 2009 | Washing Machines
Whirlpool Duet GHW9400 Water Level Seems Too Low
Scott,
Believe me, if the water level were ever several inches above the glass, you'd know about it 'cause it would flood your laundry room. Seriously. See? That rubber door boot/seal is not water tight (like a submarine) when the door is closed and locked, it's water "resistant".
Front loaders often appear as though the level is low, but they are designed this way. The clothing actually tumbles through the water as opposed to soaking in water like a top loader.
All of that to say that you have nothing to be concerned about. Your water level is fine.
SG
p.s. If your water level switch had failed, as you suspected, the water level would be too high and leak out the door.
Apr 03, 2009 | Whirlpool GHW9400 Duet Washer
Bosch washing machine
With no clothes in the washer start a program. The washe level is below the door glass. the rinse level comes up 3 cm on the glass. The washer is designed to be water efficent. If you are not getting water this high, look at the pressure switch hose, maybe it is restricted and causing the pressure to be held in the washer.
Jan 19, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
