Question about Vacuums
Do you have an instruction manual to assemble a ceiling fan with light kit. I think it's an old Hampton Bay model TU-403 file #E89510
heatman101
  • 43501 Answers
SOURCE: How to remove a Hampton
Hi.
Take the screws out of the sides of the top cover plate...drop it down, then unhook the wires and remove the screws holding the mounting plate...
heatman101
Posted on Aug 29, 2010
Obertelli
  • 3006 Answers
SOURCE: I have a 11 yr
I'm unfamiliar with your exact model but your description makes it very similar to the "King of Fans" branded models I fitted in my house twenty years ago and have fixed a few times. It might even be that yours are made by the same company as Home Depot source their Hampton Bay range from a variety of manufacturers including KoF.
You are entirely correct that you can access the pull chain once you have removed the lamp assembly. If it's just the chain which has snapped then it's normally straightforward to remove the short piece from the switch and install what's left onto the switch, but if your chain is the typical ball and link type and is more than a few years old then replace it with a new one if you can obtain the right size easily. They're not expensive, and the old one will have wear and tear making another failure highly likely. If either of the switches has failed (the pull switch or the fan direction switch) then they're also usually easy to obtain from any electronics store at low cost or you can contact Home Depot regarding spares, also check here and here. Your total repair cost should therefore be no more than a few £'s, $'s or whatever else you use locally: far cheaper and quicker than fitting a new fan.
I hope that my reply has been of use to you and saves you a lot of time and money. Please take a brief moment to rate my answer.
Posted on Oct 07, 2010
  • 377 Answers
SOURCE: My Hampton Bay ceiling remote
First, be sure you did not change one of the dip switches in the hand held unit while changing batteries. You would have to see if the switches in the hand held unit match the switch positions in the fan receiver.
This is one of the many sites you can go to for remotes:
http://www.lightinguniverse.com/fan-accessories_84.html
Hampton Bay fans are sold exclusively by Home Depot. I would check on line or stop by one of their stores to see if you can pick up a HB remote. Once you get a new remote you have to again make sure the dip switches are in the same position. Paul
Posted on Oct 11, 2010
GodBlessU
  • 3513 Answers
SOURCE: Receiver on Hampton bay the
First you need to check the housing mounted to the ceiling as the transmitter is there. Next you have to try and match it to a new remote or look for some number on the transmitter. However you can usually buy a new remote and transmitter for 30 bucks and just swap out the transmitter. This will be helpful in case you cannot match the numbers. They come labelled and r pretty easy to install. Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 31, 2010
jim4984
  • 797 Answers
SOURCE: Reinstalling a hampton bay ceiling
The black and blue wire should conncect to the black wire in the electric box and the white wire should connect to the white wire in the box. This assumes the wiring was correctly installed.
Jim
Posted on May 12, 2011
I need to replace the remote control (UC7083T) of my Hampton Bay Sidewinder 54 Ceiling fan. Could you pls tell me where to buy one? Thanks
You can buy a fan remote at Home Depot, Lowe's,or Menard's basically any one of the big box stores. If they do not have the one used with your fan,you buy a universal remote. Follow the instructions in the box make sure you shut the power off as you may get shocked or burn up he control
Feb 01, 2011 | Vacuums
My Hampton Bay ceiling remote model no. UC7030T does not work. How can I get another one. My fan will not work without it.
Oct 11, 2010 | Vacuums
I have a 11 yr old Hampton Bay ceiling fan with light kit. The pull chain to operate the fan broke (evidently inside of the fan) and I cannot figure out how to fix it. Do I have to take off the light...
Oct 07, 2010 | Vacuums
How to remove a Hampton Bay Cameron Plus Blue Ceiling Fan?
Hi.
heatman101
Aug 29, 2010 | Vacuums
Can I use a regular 2 conductor cord set on a ceiling track lighting kit and plug it into the wall? I Dont have a box in the ceiling
Yes, but make sure to use a polarized male plug ( the one with the slightly larger prong on one side).
Aug 22, 2010 | Vacuums
Change direction of rotation?
Some fans have switch on the side or on the top by the ceiling.Steve
Jun 06, 2010 | Vacuums
Vacuums Logo
124 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
