Question about Ovens
I want to install a hotpoint counter saver plus microwave oven above my stove but I do not have installation directions for this. Can you help?
  • 93 Answers
SOURCE: mounting a microwave above stove
A copy of the installation instructions for your units should contain how far it should be.Try to study it. You'll likely find that the over the range units will fit the standard 30" cabinet and also provide the required clearance to the range top. Consider the following:- power source (dedicated circuit, with an outlet box in the cabinet above). Venting (outside ot inside), and attaching method. Though they're simple in concept to install, it's a bit awkward in reality. The main thing you need to determine is sufficient space between the MW and the stove. You will have to check, but I believe you need 18" beneath the microwave. Many companies have brackets for that purpose.
Posted on Jul 25, 2008
SOURCE: Microwave on counter making wall oven change
ok the microwave has magnetic fields that may be messing it up only way is to turn microwave off or move it at lease 1 meter away from oven let me know how that goes's for you
Posted on Dec 30, 2008
  • 80 Answers
SOURCE: I have a microwave oven that I need to take out.
These are mounted thru the cabinet above. there should be two bolts which you need to remove in the cabinet abobe. remove these while you have help holding the unit. it will not drop but is kind of hinged on the wall (a lip sits on a bracket on the wall) After removing the two bolts tip the unit forward and lift off the bracket on the back wall.Don't forget to unplug it and pull cord thru cabinet as well Good luck...
Posted on Jan 19, 2009
aborcass
  • 2651 Answers
SOURCE: can a fridgidaire wall oven
heres a pdf of hte installation guide, pg 8 indicates you can and gives the dimensions/specs
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318201508.pdf
Posted on Mar 01, 2009
  • 460 Answers
SOURCE: oven doesn't turn on.
the gas flow regulator for the oven is bad and needs replaced.
Posted on Nov 13, 2009
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Reinstalling oven door which was removed by overseas movers
Have a look on You Tube, there are a number of videos that demonstrate how oven doors can be removed, it normally revolves around latching the hinge. Refitting is a reversal of the process.
The following video shows a number of different methods to remove and refit the oven door
Hopefully, one of the methods shown in the video will help you.
Jun 15, 2012 | Hotpoint Ovens
The bottem element in stove is burt out and i need direction on how to replace it
If you take the nameplate info to you supplier, you will be able to purchase a new element. Most manufacturers supply basic installation guides to help you. The nameplate is usually located on the left hand side of the drawer frame below the oven door, on the front of the appliance. If you still have further questions, this same nameplate info will help you on the manufacturers website. I hope this is helpful, Rob
Jan 01, 2011 | Hotpoint Ovens
Hotpoint microwave wp900esp23s won't heat up light comes on and table turns but thats all
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 14, 2010 | Hotpoint Ovens
Can a microwave listed as a countertop be installed over an oven or should an over the range type be installed?
over the range should be installed
they are desined to take the heat being over the stove will generate
as well as become your vent for the stove top
Oct 09, 2009 | Ovens
Mounting a microwave above stove
Jul 15, 2008 | Frigidaire FGB24S5A Gas Single Oven
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Whirlpool RMC305PDQ1 Oven-Microwave Combo Unit
is this model mounted over the oven as one piece unit?or does it hang above the stove?
Feb 20, 2008 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
512 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
