Question about Amana AGR6011VDS Stainless Steel Gas Range
Some times the burner wont ignite - Amana AGR6011VDS Stainless Steel Gas Range
  • Amana Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Sep 02, 2010
MHU45LP wont ignite all 3 burners
blocked orifices at the two burners or weak pressure from valve.Are you running nat. gas or propane?
Sep 18, 2014 | Mr. Heater MHU45LP
I have a HD2515U Stainless Steel Dual Fuel stove (hooked up to propane, not natural gas). Oven still works, but burners wont ignite. It has electric ignitors. I've followed all the steps to make sure...
The wiring harness for the burners sound like is shot! I would think about buying a new one! have You tried to light the burners with a lighter or match to see if they will ignite? If so,replace the wiring harness, over time they go bad and short out! If You Can use lighter to ignite burner I would use the long nosed ones like You start charcoal with till The new wiring harness arrives! You will save the hair on Your arm that way! LOL! Good Luck!
Jul 14, 2017 | Siemens HD2515U Stainless Steel Dual Fuel...
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Igniter won't stop
Normally you would find the switch that is stuck in the "ON" position by carefully removing one wire at a time, taking care not to get bit. LOLb2adc18.jpg
Looks like you might need Number 5.
Your model does not sell individual switches.
$69
Sep 26, 2010 | Whirlpool SF367 Gas Kitchen Range
Pilot stays lite but the burner wont ignite propane unit
the gas is not coming out of the burner, probably due to rust clogging the holes.
Dec 04, 2009 | Water Heaters
I get an ignite but my burners wont light. I have
did you try replacing the battery? it is inside the ignitor button.
Aug 04, 2009 | Ducane 30400042 (LP)
Ignites then burner shuts down then rignites over and over wont dry
Check your connecting exhaust vent for a blockage.
Remove the vent and run a 45 minute timed dry load and see if it works correctly.
Report back.
Apr 12, 2009 | Dryers
Gas furnace wont stay lit
sounds like the thermocouple that senses when the burner ignites is faulty. when the burner is first lit it looks for a signal from the thermocouple telling it that it has ignition. i have had some luck removing the part (furnace off) and sanding it clean. this is located in front of one of the burners..Good luck
Jan 15, 2009 | Central Dual Temperature Heat Gun Kit...
Amana AGR6011VDS Stainless Steel Gas Range Logo
143 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
