Question about Whirlpool Washing Machines
Water wont shutoff when filling - Whirlpool Washing Machines
  • 262 Answers
If you unplug the machine and it still fills with water, Then your water valve is bad, Use the wall shut off to find out what side is bad by turning on one at a time so you can find out if hot or cold valve.
if the water quits filling when you unplug the machine then you have a water level switch problem or the water level switch hose is disconected or cloged.
Posted on Sep 02, 2010
I have a EIDW6105 Electrolux dishwasher and it will not fill with water. Can hear a humming but no water entering the tub. Water is set on 120 degrees and and no lines are cramped.
open the door,look on the front of tub i believe your float switch is on the left side,make sure nothing is under it holding the float up,this will stop the water from entering,if that's ok you could have frozen pipes or valve,i've seen a ton of them in my area,or a bad house water shut off or a bad water valve on dish washer part 154513601,remove the bottom panel you'll see the valve on left side,you can crack the fill line with a wrench and see if any water comes out,if the valve is humming most of the time this is from no water getting to the valve,if it's frigid temps. where you live most likely the pipe or the valve is frozen,you can get a hair dryer and heat the valve up to see if that helps but make sure your shutoff works under the sink,also at night leave the doors under the sink open and remove the bottom panel to the dish washer all winter so warm air can get under and around the valve and pipes,if it isn't froze shut off the water at shutoff under the sink,remove the water fill line from the valve syci the line in a bucket or glass and open the shutoff,if water comes out the valve is bad hope this helps.
Jan 13, 2018 | Electrolux Dishwashers
SHE043705UC/4H fills with water but does not wash. Have to hit the two buttons to get it to drain. Was settin up for awhile
Look for the automatic shutoff switch underneath the machine left side , hard to find. might have to take machine and tilt it way over to find. just push switch up to reset.
Mar 28, 2014 | Bosch 24 in. SHU43 Built-in Dishwasher
Washer wont fill with water but water inlet valves are good
Check the float switch and the water shutoff valve inside the machine
Mar 11, 2014 | Samsung WF330ANW - 3.7 cu. ft. Washer-...
Tank wont refill after flushing.
The ball **** controls the water flow into the tank when flushed. If the float is stuck in the up position, the water will not fill the tank or the valve could be defective. If after pushing down the float and observing little or no water you need to replace the ball **** or the water valve is turned off. Turn the water off at the shutoff valve. Put a towel under the water supply hose and unscrew the water supply hose at the bottom of the ball ****. Drain any excess water at the bottom of the tank using a shop towel or paper towels ringing them out when they become saturated with water. Remove the ball **** and replace the old one with a new one available from a hardware store. Make sure to follow instructions on washer placement to avoid leaks. Replace the water supply hose and tighten snugly and be careful not to over tighten to crack any plastic. Turn on the water shutoff valve and adjust the float so the water stops at the tank water line.
Sep 07, 2009 | Kohler Home
Water will not stop filling wash basket, even when off
Your water fill (mixer) valve is failed in the open position.
CLICK HERE for the part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 20, 2009 | GE WBSE2090A Top Load Washer
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
ICEMAKER NOT MAKING ICE
Dear Customer
Please perform the following checks
Please rate this ,Thank u
Dec 17, 2008 | Refrigerators
Overflow - Cold water shutoff not working?
Sounds like the cold water valve is faulty. You can try to remove it and clean the inside if it's clogged or replace it completely.
Jun 25, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
