Question about Brother HL 1440 Laser Printer
HL-4040CN don't show or read new refilled magenta cartridge.
Please help. My HL-4040CN is only 3 weeks old. Two days ago I refilled my yellow cartridge, it works and the print quality is as good. Today I refilled my magenta cartridge and to my disappointment the LCD don't show or read the magenta refilled cartridge, and the printer won't print.
  • 1 more comment
  • Sunny10 May 14, 2008
    The magenta cartridge emptied that's why I refilled it, meaning it was working and not defective before I refilled it. Anyway, before I got your message I bought a new cartridge, sucks, and it's now working. The bottom line is, I want to refill my cartridges when they empty so I can save on toners. Is this possible in my unit?
  • ctnozil Jun 09, 2014
    When the cartridge shows toner empty. you need to reset the message when you replace a refilled cartridge, but if it is a new original cartridge it will reset automatically.
    Use original.
    Problem Solver:
  • 8 Answers
Resetting the gear will inform the printer that your cartridge is new and is ready to print. Some people reset the gear to try and use up as much of the toner that is left as possible . to help do this cover the small clear window on the cartridge with a black sticker os the printer cannot see how low the toner level is.
Before refilling you must first empty the old toner
http://www.zinetic.co.uk/video/tn135.aspx
Posted on Mar 15, 2011
    Novelist:
  • 105 Answers
If you have removed and reinstalled the magenta cartridge several times, it is very likely the cartridge is defective out of the box. If you have another magenta cartridge, put that one in and see if the problem resolves. I'm betting it will. If that second cartridge does work, then return the defective cartridge to where you purchased it - they should replace it without a hassle.
Posted on May 13, 2008
  • Neal Brown May 21, 2008
    Refilling inkjet cartridges is a risky proposition. In my experience, it does not work out better in the long run. Often you will refill a cartridge with ink that you cannot recover and then the cartridge stops working - such as what happened.
    With the new cartridges if they don't work, you can at least get them replaced. When it is a refilled cartridge, you are on your own.
    I also do not recommend buying generic cartridges, preferring to stick with OEM only.
HL 4040CN is printing with a pink tint, it also says drum end soon and has said that for a while. What sould I do?
I have a similar problem now: magenta stain over the entire page when printing anything with any color (even just a hyperlink); B&W text is no problem.Not the PC; even the Demo Page from the 4040 menu does this. Updated the 4040 firmware tonight to latest (1.24, etc), but no better.Recently replaced the Magenta cartridge (official Brother cartridge), though saw this problem near end-of-life of the previous Magenta cartridge. Drum Unit status is 42%, so not expected to be near end-of-life.
Nov 28, 2011 | Brother HL-4040CN Laser Printer
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
Can someone please help me i have just printed off 400 prints with my brother hl 4040CN laser printerits brand new and its now saying my cyan toner has ran out this is impossible i am right in the middle...
Your toner usage will depend upon how much of each color toner is used on each page. (To conserve colors when printing in Black and White only, specify monochrome in your printer setup) <div>I had similar problems when printing publicity flyers. The toner cartridges claim to be good for about 2000 prints each, but I was lucky to get 3 or 400 pages when printing blocks of color. The TN115 cartridges hold significantly more toner, and the cartridges that come with the printer are TINY.</div>
Jul 06, 2010 | Brother HL-4040CN Laser Printer
The alarm light is blinking and the toner was changed 3 days ago. Minimal printing since then
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 14, 2009 | Brother HL 1440 Laser Printer
Model HL-4040CDN, told me to change magenta toner
Have the same problem, can't find the solution. Filed a complaint on the brother website feedback link, hopefully they will resolve if more people post problems with toner cartridge changes
Nov 10, 2009 | Brother HL-4040CN Laser Printer
Printer does not recognize new cartridge was installed this is the second time is happening please how can i fix this problem , but if i bye an other it will recognize it again please why
Are you using a factory new ink cartridge?
Don
Oct 27, 2009 | Brother HL-4040CN Laser Printer
Using the same cartridges for the HL-4070CDW, I refilled the black yellow cyan and magenta cartridges. when I put them all back into the printer, the RED toner life end comes on saying that cyan, magenta,...
There's a window on each end of the cartridges and light shines thru to show when they're empty, your refill toner may not be the right density. If you put a small piece of electrical tape over the windows on the cartridge, the error will go away, but you have to watch print quality to change or add toner.
Aug 11, 2009 | Brother HL-4070CDW Printer
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Brother HL-4040CN won't read or show new refilled cartridge in the LCD
I think I know what the problem is...
When you refill these toner cartridges you need to reset the "toner empty" cog wheel.
For instructions on how to do this follw this link:
http://www.proprint.co.uk/brother_hl4040.htm
It has pictures and explains how to reset the cartridge
Good luck,
Billy.
May 11, 2008 | Brother HL 1440 Laser Printer
Not printing magenta
Try cleaning contacts with a lint-free cloth or pencil rubber , touch the nozzle area with a cloth dampened with WATER, see if magenta appears. If nothing works, change cartridge...
Nov 07, 2007 | HP Deskjet 5440 InkJet Photo Printer
Brother HL 1440 Laser Printer Logo
359 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
