FixYa.com
Tags:
Lexmark X3470 All-In-One InkJet Printer
My new lexmark X3470 printer (by 2 users)
posted by compudummy on May 10, 2008
Can anybody tell me if my Lexmark X3470 printer is compatible with windows vista, and if not how can i fix it? I have had problems with my old printer on windows vista and i want this printer to work! Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by DWHISKEY823, posted on May 17, 2008
WHEN I TRY TO PRINT TEST PAGE IT SAYS ITS NOT CONNECTED, WHEN I TRY TO PRINT FROM PUBLISHER IT SAYS IT ISNT INSTALLED
Best Solution
posted on May 10, 2008
Helpful (85)
ginko
Rank:Guru Guru
Rating: 88%, 490 votes
Yes, select the tab labeled Specs under the printer picture on this link, and check specifications. Vista is listed as a supported operating system.
Rating Locked! (?) compudummy has rated this solution as Helpful
Solution #2
posted on May 20, 2008
Not Rated (0)
Hub1
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
I had the same problem. These are the steps that I took to resolve the problem:
1.Please load the Lexmark CD and cancel the installation screen.
2.Go to "Start" and "My Computer."
3.Right Click on the the CD-ROM drive letter (for example, D:).
4.Choose "Explore."
5.Please double click on the "Applications" folder to open it.
6.Please double-click on the "Setup" icon to install the "All in one center."
7.Please follow the on-screen instructions.
The CD of the printer will be needed. Each folder has a setup launcher.
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on May 18, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
yes it does work with vista but be warned when you try and change the ink it may say cover is open and that is the end of that I used my printer 3xs and had to go out and buy a new one
Can you Help with these Printers problems?
Mode stuck on copy
The mode selector on my 3430... Answer This...
Cannot Install or Uninstall...
I just recently tried to... Answer This...
fax hp office jet j5780 hook up
i have to hook up my hp all in... Answer This...
Software Problem
Hi my name is Max. I have an... Answer This...
bad color/print quality...
the very first thing I printed... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
