Question about Bosch Axxis WTA 3510 Electric Dryer
My Bosch Axis Dryer (V20-UL), electric, external vent, brand new, never used until it was hooked up today, tumbles but doesn't get hot. Anything I can do before I call servicing or return it??
    President:
  • 3,074 Answers
If you have a multimeter you can check to make sure 220 volts.
Posted on Sep 02, 2010
How do you turn off the end of cycle beeping on a Bosch V20-UL dryer?
pg 16 says at end of cycle damp dry is emitted (if set)
That is the only thing I saw that had anything to do with sound.
http://laundry.manualsonline.com/manuals/mfg/bosch/v20ul.html?p=8
I went to this link and opened as pdf.
Dec 01, 2015 | Dryers
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
Bosch tumble dryer
Try holding down the start button for 10 sec's to reset it.
Jan 15, 2014 | Dryers
My Bosch dryer gets hot and tumbles but clothes come out hot yet very damp.
Hi eyecunow115
Check your vent, if your dryer vent hose/pipe is plugged up it will cause the problem you are have.
Also a plugged vent can cause a dryer fire so make sure that the vent is totally free of lint so the heat can get out of the dryer and to the outside Please take time to rate me
Bud
Oct 14, 2012 | Bosch Axxis WTL 5400 Dryer
Heats spins but doesnt dry. its clean and lint free there is no exterior vent on it bosch axxis v20-ul thx
If you have heat, then it's an airflow issue as inside your dryer you have several thermostats, one is called the high limit thermostat, when the dryer can not vent properly, the heat builds up in the dryer and this thermostat cuts off the heating element for safety reasons, and the heat may not come back on for 20 minutes, I understand there is no exterior vent but the dryer does vent air. More then likely once you take the dryer apart and clean the lint out of the inside it will run correctly. Hope this helps Tim
Mar 11, 2011 | Bosch Dryers
My WTL 5410 dryer (electric condensation) has hot air coming out of the low rear duct opening (where the condentate hose connection is located. The hose is properly connected and occationally has water...
Welcome to FixYa.
You are correct, the unit being a condenser model doesn`t require any additional venting or exhaust to outdoors, that is the purpose of condensing the moisture internally.
As to the issue of air flowing out of the unit I`d suspect perhaps the heat exchange may need cleaning, if it is plugged it will cause the air to be directed elsewhere.
I`ve attempted to attach below the procedure for cleaning, if unsuccessful for whatever reason, too small for example, you or your landlord can email me at macmarkus@live.ca and I can send you the "pdf" guide for your Bosch dryer.
Keep me posted on your findings and I`ll try to assist you further if need be.
Thanks for choosing FixYa today and good luck.
Please take a moment to rate the info presented and leave a testimony if you feel it warranted.
Regards,
Macmarkus :)
Sep 28, 2010 | Bosch Axxis WTL 5410 Electric Dryer
I have a Bosch V20-Ul dryer that is 2 years old. Suddenly stopped creating heat. The dryer drum turns but no matter which cyle I select, it spins for about 1 min, then stops, beeps and the wrinkle block...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 09, 2010 | Bosch Axxis WTA 3510 Electric Dryer
The pipe dosent seem to be letting out the steam and its going to the bottom of the tumble dryer
You most likey have a plugged vent ppe or the pipe is to long or have two many bends in it. try laying the vent pipe out and see if you can see anything in the pipe. Next if the pipe is clear check outthe vent door and make sure it is not plugged or the door is not frozen shut.
Oct 02, 2009 | Bosch WTE86300 Electric Dryer
Maytag dryer model # SDE3606AWY HEATS UP TUMBLE clothes but does
There is most likely a lint obstruction somewhere in the exhaust. Start by checking the outside vent as often there is an animal screen on it that over time gets caked with stray lint. If that's clear then work backward and check the hose, etc until you either find something or get to the dryer itself. It's possible that in the internal exhaust tubes there's an obstruction as well so if you don't find anything in the external tube you will need to disassemble and have a look inside those internal exuast tubes/ports. If it's inside then do it soon as there's clearly a risk of fire if there's a wad of lint somewhere inside where it shouldn't be.
The mother of a friend at work had this issue - her clothes took HOURS to dry. Her animal screen had several inches thick layer of lint. Once that was removed the dryer dried like new.
Mar 29, 2009 | Maytag SDE3606A Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
314 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
