Wall unit makes gurgling noises and bangs - Heating & Cooling
  • rw60 May 10, 2008
    This is a Panasonic split system about 7.5 kva (not an inverter) we use it more for heating than cooling but it does it more on heating cycle, happens not all the time just every now and then. Sounds as if its gas noises in the wall unit pipes startles you when it happens. Bang sounds a pressure valve releasing abruptly?/ Compressor is outside
  • 828 Answers
Is this a heating unit or air conditioning unit?
Posted on May 10, 2008
  • James Helmer
    James Helmer May 11, 2008
    On heat/cool pump systems there is a reversing valve in the outside unit that changes the gas flow. When you change from heat to the cool mode there will be a change in pressure due to the reversing of the gas flow. The sound you are most likely hearing is this valve operating in a normal manor.
One morning my son drove my car home and got it in the driveway n it made like a gurgle noise n died. After that it turns over but won't start.
Year make model? Possible fuel pump issue not supplying fuel. You can try banging on the fuel tank with your fist while someone cranks the car over. If it starts or tries to start using this procedure, the fuel pump will have to be replaced
Jul 12, 2015 | Cars & Trucks
Ticking Noise in my Fujitsu Mini Split Indoor Unit
does the ac continue to make the noise even in fan only mode or is only in cooling mode. If only in cooling then it could be a gas related problem or blocked coil.
Nov 07, 2014 | Fujitsu 12RLS Wall Ductless Air...
Dometic banging noise
Not real sure what could be banging and clanging as there aren't really any moving parts. There have been some reports of gurgling sounds coming from the cooling unit and also water pipes 'hammering' when the pump is on.
Mar 09, 2014 | Dometic RM2852 Refrigerator
Frigidaire in wall air conditioner making noise fan/ motor?
Is it a clicking or banging sound? The fan is most likely not kicking up the moisture to cool the evap coil off enough in the unit so you might here more noise for a little while. Monitor it and let me know if anything changes.
Sep 05, 2012 | Frigidaire FAH106N1 Wall/Window Air...
New cozy wall heater makes alot of noise from heatexchanger poping and banging noises
if this is a w series unit measure from the top of grill to the floor, should have 68 3/8 on an inch if not the header plate which is installed in the wall was put in wrong have the installer correct this and the noise will go away. Cozy tech line is 502-589-5380 have the installer call so they can go over the install of the unit.
Dec 06, 2010 | Cozy (W352E) Heater
Unit has stopped cooling and freezing also making gurgling noise
it sounds like the frezzer fan stoped and what your hereing is the freon coming in
Apr 17, 2009 | Refrigerators
Whirlpool gold makes banging noise
If the refrigerator is working fine the banging noise you hear is the isulation inside the refrigeratior walls that exand and cotract with the change of temperatures. you don t have to worried about it.
Apr 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE Stainless Steel side by side freezer noise
sputering and gurgling is a common complaint with lots of models. it is the surculation of the refrigerant thew the evapurator tubing behind the rear wall. make shure the units condensor underneathe the fridge is clean and clear of dust. it can cause the head preasure from the compressor to increase witch can cause excesive sound in circulation. hope this helps you
Oct 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Suddenly no filtered water comes out, but there are gurgling sounds inside
I guess make sure the filter didn't unseat itself first, also check the O-rings, etc. to make sure they didn't roll off their position on the filter. If that's all OK, you really need to find that gurgle sound cause that's likely the water you are missing going "somewhere" it's not supposed to go. Look all over for water leaks even if you have to pull the unit out from the wall... keep looking!
Dec 21, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Heating & Cooling Logo
352 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
