Question about Sony Handycam CCD-TR517 Camcorder
I put in the cassette and press play but it plays with lines gong down then it stops and says c:31:22 how can i fix that?
    Genius:
  • 1,812 Answers
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 03, 2010
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Cassette deck stops immediately after pressing play
It is likely that the rubber drive belts have deteriorated and will have to be replaced to restore operation.
Apr 21, 2013 | Audio Players & Recorders
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
I have memorex radio/cd/cassette player model MP3226. The PLAY button on the cassette tape does not stay in the down position when pressed when a tape is in the housing. If I remove the tape, and press...
I can imagine 2 cases for your problem:
Either there is a mechanical problem and something is not allowing the "play mechanism" to go all the way up to the clip position when the cassette is in the housing,
Or the tape isn't rolling up properly. Some of these deck's have some kind of protection and when the tape isn't rolling properly a system stops the play procedure. Check if both of the rollers for the tape are spinning around properly. In case of not spinning, run the cassette fast speed forward and backward in order to come to the proper state. Also check without any cassette is any roller spinning around or not?
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 15, 2011 | Memorex MP3126 Cassette/CD Boombox
I have a TDK HD-01 head demagnetizer for cassette decks, but I have lost the instructions. Could you help?
Hi there.
First - Turn On The Tape Demagnatiser (should be a switch on it)
Second - Insert into cassette player
Third - Turn On cassette player
Fourth - TURN DOWN VOLUME ON AMPLIFIER TO MINIMUM (This is essential!)
Fifth - Press Play on cassette player
Sixth - After 10 seconds press stop on the cassette player
Seventh - Remove the cassette demagnetizer from the cassette player
Eighth - Turn off the demagnetizer and put back in it's usual storage place
AGAIN, MAKE SURE THE VOLUME IS TURN TO MINIUM WHEN USING THIS AS THE NOISES CAN DAMAGE SPEAKERS.
Jan 07, 2011 | Audio Players & Recorders
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Jvc a 55u plays a movie from the store but I cant get it to tape a regular tape,it's a nice vcr and I have never seen this problem, the moves from the store are played great but when I put in my own tape...
Hi Diane,
Just downloaded the manual for your vcr it says:
1 Press menu
2 press up/down arrows to Function Set then press ok
3 press channel up/down arrows to Auto picture then press Ok or shuttle plus right arrow to set to on or off when using rental tapes set either to on or off to give the best picture
4 to return to normal press menu
For recording
1 load a cassette make sure the tab on the cassette is intact if not put some cellotape over the hole
2 set channel press up/down arrows then press enter
3 select tape speed sp/ep
4 press and hold rec and press play on remote or just press record on unit
5 to pause recording (cut out ads) press pause on remote to continue again press play
6 to stop recording just press the stop button
hope this helps and reflects in my feedback lol all the best
Jim Scott
Feb 28, 2009 | JVC HR-VP693U VCR
Eats my Cassette Tapes
Ok sound like the play head is out of a-line ment - easy way to fix if it is this - remove from the mains supply and open the cassette deck door - press the play button down and look at the play head there is 2 screws 1 either side 1 is fixed and 1 is sprung - now inset batterys (much safer) - try and fit a cassette in without using the cassette door should just fit in then press play and ajust the Right hand side scree with a small screwdriver (insulated) and ajust slightly to the left or to the right and this should fix the chewing - to get it just right use headphones ajusting left to right will tke the sound + & - to each earphone. Warning dont turn to far to the left as this will undo the screw completely - u have a least 1 whole turn either way is fine
Nov 20, 2008 | TruTech T350B Boombox
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
The unit will fast forward and rewind, but won't play
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but
Nov 22, 2005 | Sharp VC-H810U VHS VCR
Sony Handycam CCD-TR517 Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
