Question about Briggs Stratton 7,000 Watt Automatic Home Standby System with 50 amp
Hello I have a briggs generator model # 030358. Serial # 1016827364. It keeps flashing codes c1 four times and c3 four times. Everything seems to be running fine and it still has power but can't find the manual to know what the codes are.Just want to make sure it is not going to blow up. Any assistance would be helpfull thank you.
  • 2 more comments
  • Robert
    Robert Sep 03, 2010
    what is the wattage
  • Robert
    Robert Sep 03, 2010
    wher are you seeing this code the manual does not show a control pannel that supports this feture
  • turkeytown Sep 03, 2010
    it is a portable gen. 7000 watt start up 6500 run power
  • turkeytown Sep 04, 2010
    I was wrong it is 7750 start up wattage and 6200 run power
2 Suggested Answers
SOURCE: No power output from Briggs & Stratton ProMax 7500E generator
check the AVR.
Posted on Jun 14, 2010
2000 cadillac deville gas gauge avg went blank car won't start
Your best bet is have it checked for DTC'S - diagnostic trouble code's first before doing anything ! Sorry but you have no idea of the complexity of this vehicle .
Body Control System Circuit Description
The body control system consists of three modules, the Dash Integration Module (DIM), the Instrument Panel Integration Module (IPM), and the Rear Integration Module (RIM).
Battery Positive Voltage (B+) is provided from IGN SW fuse 20 in the Rear fuse Block on CKT 540 (ORN) to the DIM at connector C3 terminal G. The module ground is on connector C3 terminal E, which is wired to ground G201 by CKT 451 (BLK/WHT). Battery positive sense voltage is provided from DIM fuse 39 in the Rear fuse Block to the DIM at connector C3 terminal A12 on CKT 3340 (ORN). This battery input is referenced to the ground sense input at DIM connector C3 terminal B12, which is wired to the battery negative terminal and to ground G307 on CKT 50 (BLK). These sense inputs are physically connected to the battery positive and negative terminals for accurate battery voltage readings. The DIM is wired to the Class 2 serial data line CKT 1807 (PPL) at connector C2 terminals A11 and A12. The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
Instrument Panel Module (IPM)
Battery Positive Voltage (B+) is provided from I/P fuse 7 in the Underhood fuse Block on CKT 440 (ORN) to the IPM at connector C1 terminal C1. Ignition Positive Voltage (IGN3) is provided from the IGN3 RR fuse 6 in the Rear fuse Block to the IPM on CKT 41 (BRN) at connector C1 terminal C2. The voltage inputs are referenced to the module ground at connector C1 terminal D16 on CKT 451 (BLK/WHT). The IPM is wired to the Class 2 serial data line CKT 1807 (PPL) at connector C1 terminals C7 and C8. The various IPM input and output circuits are described in the corresponding areas as indicated on the IPM electrical schematics.
Battery Positive Voltage (B+) is provided from IGN SW fuse 20 in the Rear fuse Block on CKT 540 (ORN) to the RIM at connector C1 terminal A1. Ignition Positive Voltage (IGN1) is provided from IGN1 fuse 12 in the Rear fuse Block on CKT 1039 (PNK) at RIM connector C1 terminal A3. These voltage inputs are referenced to module ground at connector C1 terminals B7 and B8 on CKTs 1051 (BLK). The RIM is wired to the Class 2 serial data line CKT 1807 (PPL) at connector C2 terminals B3 and B4. The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
Aug 11, 2016 | Cadillac Cars & Trucks
I want a restriction code for my nokia c1-01EIMI 353262/05/723795/9
Hello. You can get the accurate restriction code for your Nokia C1-01 from ClassicUnlocking.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia C1-01 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C1-01.
3 - Compose #pw+CODE+1#.
4 - The Nokia C1-01 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C1-01 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C1-01
Sep 24, 2014 | Cell Phones
Swingline model 67 repair
Look on YouTube for videos on how to flash the field on a generator.
Sep 05, 2014 | Electrical Supplies
How to delete the data but keep the formulas
Formulas don't usually contain data, but display some transformation of data held in cells that do contain the data.
ie cell C3 may have a formula that says "=C1-C2"
Which means that C3 will display the result of the operation of subtracting the content of C2 from the value held in C1"
Clear out only the cells that contain the source values (C1 & C2) and your formula (C3) will remain.
Aug 29, 2014 | Computers & Internet
Xerox workcentre 5020/Dn c1 error
i have one xerox 5020 machine, there is display showing C1 error code in first tray and C3 error code in bypass tray .if open and close the machine will be idle and ready to cpoy. there is no paper pick up in both trays. please help to resolve the problem.
Dec 17, 2012 | Office Equipment & Supplies
IFORGET MY SECURITY CODE FOR NOKIA C3 NEED HELP IEMI 355933/04/154701/2
Hello try with the default code 12345.....this should works unless you/someone had not modified.If the default code doesn't help there is a way to reset or generate.Please visit mobile repairing shop..there they can generate the current code and the same time they can reset it to default code without missing user data.Good luck.Thanks for visiting fixya
Jun 28, 2012 | Nokia C3 Cell Phone
My Nokia c3 is asking unristricted code but its serial number is ending with a question mark..the Serial Number is 12345610654321? PLEASE SUPPLY ME WITH ITS CODE
i think your device need to full flash, but probabilty of this device to recover is 10% chances. show some repairer. he will guide you.
Jun 21, 2012 | Nokia C3 Cell Phone
C1-01
hi are you in need to unlock network in your Nokia c1-01 mobile then codes are the best solution .codes generated by calculator seems to be wrong in many times if you entered the wrong codes many time your mobile get hard locked then it cant be unlocked .so better try codes from online providers .to purchase codes visit mobileunlocksolutions.com here they ask you the network name to which your mobile is locked then the imei number of your mobile .finally they send you codes to unlock your mobile from network.
Apr 03, 2012 | Nokia C101 Cell Phone
ENGINE RUNS BUT NO POWER TO OUTLETS
When you flash the field, are you going + 12 volts to the top or right side brush? Negative to the other brush? Try three times for 2 seconds?
Sep 25, 2009 | Coleman Powermate Premium Plus 6250W...
Briggs Stratton 7,000 Watt Automatic Home Standby System with 50 amp  Logo
124 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
Mike Carew
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
