Question about Bosch 24 in. SHX36L05UC Stainless Steel Built-in Dishwasher
I can't read the cycle names. I cleaned the door, and the cleaner wiped out the painted on names of the cycles. I can't seem to find this info in any literature. I know that there are 4 cycle buttons and the last one is rinse & hold. Does someone know which is which?
  • 109 Answers
SOURCE: Bosch SHU430UC/06
ok first of all there is a drain pump and wash motor pump. which one is running?Then tell me what kind of buttons u have.Are the touch buttons or plastic buttons that move
Posted on Dec 15, 2007
SOURCE: Dishwahser rinse cycle running for hours
I have a Bosch SHU5316 -- same symptoms -- turned out to be the control module (the thing with the lights & buttons on it). First replaced under parts warranty. The next time, I did it myself (you take part of the door apart). Not too bad to do, but the module cost about $100. Since this was the second time it happened, I bought a "lifetime" replacement warranty on the module ($10). Best ten bucks I ever spent. I am on my third module.
Posted on Jul 23, 2008
jonniewalker
  • 1029 Answers
SOURCE: Poor cleaning results in 4 year old dishwasher
  • check out all these for a way out
  • Check for adequate water level
  • Check the spray arms and spray tower
  • Check the water temperature
  • Check the detergent cup
  • Clean the fine particle filter
  • Check the inlet filter screens
  • Check the water pressure
  • Test the water inlet valve
  • Check the drain valve
  • Test the selector switch
  • Test the timer motor
  • Test the heating element
  • Test the bimetal terminal assembly
  • hope this helps appreciate by rating it
    Posted on Sep 18, 2008
    abhishek33
    • 1239 Answers
    SOURCE: Electronic Timer sticks on Wash Cycle
    hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
    If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
    The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
    After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
    Posted on Nov 10, 2008
    mark_37388
    • 100 Answers
    SOURCE: My Bosch Dishwasher cycle runs for 2 plus hours!
    If this unit is running for a long time it is because it is still try to heat the water temp up it is eather the control board or the heater.
    Posted on Mar 28, 2009
    How to clean my jen air built in oven
    For basic cleaning, use a non-abrasive cleanser or detergent and water. Clean the oven frame, oven door outside of the gasket and the gap in the gasket. (Don't clean the gasket.) With a damp sponge (with detergent if needed), wipe up any spills in the oven. (Sugary or acidic spillovers could damage the porcelain.) Wipe up any grease that spilled in the oven. Wipe the control panel with a damp cloth then dry. Clean the oven door with detergent and water. Clean the window or glass with detergent and water or glass cleaner. Use care to keep the water from seeping behind the window.
    Next if you want to do a self-cleaning cycle. Remove the oven racks, the broiler pan and any other pans or items that are in the oven. Close the oven door. Press the Clean pad and then press Autoset(0) button to get the length of time to run the cleaning cycle. Press 2 or 4 to shorten or lengthen the cleaning cycle. After 5 seconds the door will lock and the cleaning cycle will begin. The door will remain locked until after the oven cools down (at least an hour after the cycle ends). Wipe up any white ash after the oven door unlocks. If you want the cleaning cycle to be delayed, press the Stop pad within 5 seconds of setting the length of the cleaning cycle. Use the number pads to set the time that you want the oven to end the cleaning cycle. (Make sure that it is later in the day with sufficient time to run the cleaning cycle.)
    Most Jenn-Air manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . The direct link to the manual for the JJW8530CAA is http://www.kitchenaid.ca/assets/pdfs/literature/JJW8527AAB.pdf .
    I hope this helps.
    Sep 11, 2011 | Jenn-Air JJW8530C Expressions Collection...
    How to clean oven model JSP46D P1BB
    That model is self cleaning . So you have to remove the oven racks and press the button marked self clean. The self cleaning cycle will last anywhere from 2-4 hours . once the oven unlocks after the cycle is over you have to wipe the surface with a clean clothe. It is very important to never use regular oven cleaners (i.e. Easy Off ) in a self cleaning model. If you need to spot clean something without using the Self cleaning mode you can make a paste of baking soda and water and let it sit for an hour before wiping.
    As far as the top is concern, use a mild soap and a dish cloth on an everyday basis. There is products specifically designed to clean the ceran tops (good brands are "Cerama Bryte" and "CookTop", they are available at any Wal Mart) you should use one of those cream cleaner at least once a week. If something is really baked on , you can use a razor blade ( same ones ones used to removed paint off windows) or a scotch brite pad ( the blue one only.. the yellow one is too abrasive)
    Mar 14, 2011 | GE Ovens
    I tired setting the bottom oven to the clean cycle, it switched on for a few minutes, then locked. It didn't finish the clean cycle and the door remained locked. I have tried setting the clean cycle...
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
    Nov 29, 2010 | Jenn-Air Electric Double Oven
    I have never used a self cleaning oven.i have already put oven cleaner on the inside and let it stand for awhile is this right? god I don't want to blow up
    You DO NOT use a oven cleaner with a self cleaning cycle. Wipe out the oven cleaner as instructed on the can. Oven cleaner is better than self clean cycles anyway. Most self clean cycles eventually cause oven control problems.
    Oct 08, 2009 | GE JGRP20 Gas Single Oven
    Are there any special steps to self clean the oven?
    Please follow the steps:
    Run the self-cleaning cycle for your oven as often as you need to. It reduces almost any spill to a powdery gray pile of ash that can easily be wiped away at the end of the oven's cleaning cycle using a damp cloth. Make sure you have a window open during the process, to help keep smoke from sticking to walls and your ceiling. You may need to wash down the oven door and frame with a gentle cleaner to remove soil residue. Don't scrub the rubbery gasket that seals the oven door. Just rinse it with dish soap and then water. Don't use abrasives, or oven cleaners on the interior of the oven.
    Thanks
    Aug 29, 2009 | Ovens
    My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
    run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
    this may take multiple cycles to rid of odor.
    For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
    Also clean your drain pump filter at bottom front behind access panel.
    If boot is really bad , replace.
    Jul 16, 2009 | GE WSXH208A Front Load Washer
    How long does the oven take for the self-cleaning cycle?
    Most self clean cycles take 4 hrs.The oven is gradually heated up to 950 degrees F which takes up to 1 hr and after the 4 hrs is up it takes some time for the oven to cool down before the door will unlatch at below 550 degrees. You can self clean your oven 2-3 times for the price of a can of oven cleaner and without the elbow grease involved. You should not use harsh oven cleaners on the soft porcelain on your oven liner or it could be damaged. Before you put your oven into self clean you should wipe out any excess spillage with a damp soapy cloth and after cleaning you wipe away the ash with a damp cloth. If you do not want the oven racks to take on a blueish to ugly gray tint do not leave them in the oven during the clean cycle.
    please rate my answer
    Jul 03, 2009 | Kenmore Kitchen Ranges
    I need direction on how to start the clean cycle on my jenn air
    CLEAN PAD
    Use to set a self-clean cycle or a delayed
    self-clean cycle. One press of the Clean
    pad sets up an immediate clean cycle. A
    second press of the Clean pad sets up a
    delayed clean cycle.
    • Clean oven
    frame, door
    frame (area
    outside of gasket)
    and
    around the
    opening in the door gasket with a nonabrasive
    cleaner such as Bon Ami*. These
    areas are not exposed to cleaning temperatures.
    • Remove air grille.
    • Remove oven racks. If racks are left in
    during a clean cycle, it may impair function
    and they will discolor. Turn off the
    oven light and close door.
    * Brand names for cleaning products are
    registered trademarks of the respective
    manufacturers.
    TO SET FOR IMMEDIATE START:
    1. Press Clean pad once.
    2. Press the Auto Set pad for 3 hours of
    cleaning time, press again for 4 hours
    and again if 2 hours of clean time are
    desired.
    3. CLEANING and LOC plus the clean
    time will appear in the display.
    4. When the clean cycle is complete,
    CLEANED will be displayed. LOC will
    remain on until the oven has cooled
    (approx. 1 hour).
    5. When the oven is cool, LOC will no
    longer be displayed and the door may be
    opened.
    6. Wipe out the oven interior with a damp
    cloth. If soil remains it indicates the
    cycle was not long enough.
    TO CANCEL SELF-CLEAN:
    1. Press Cancel pad.
    2. If LOC is NOT displayed, open oven
    door. If LOC is displayed, allow oven to
    cool.
    Thanks for using Fix Ya, Please take the time to rate this solution.
    clarkco
    Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
    GE Electric Double Oven Door Will Not Unlock
    heatman101
    Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
    Self cleaning
    You can go to the Maytag web site and download the manual.  www.maytag.com, or go to http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
    and download the manual CAUTION
    • It is normal for parts of the ovens to become hot during a self-clean cycle.
    • To prevent damage to oven doors, do not attempt to open the doors when LOCK is displayed.
    • Avoid touching doors, windows or oven vent area during
    a clean cycle.
    Do not use commercial oven cleaners on the oven finish or around any part of the ovens.  They will damage the finish or parts.
    Do not leave baking/pizza stone in the oven during self-clean.
    The self-clean cycle uses above-normal cooking temperatures
    to automatically clean the oven interior.
    The oven should be cleaned regularly by wiping up spillovers
    to prevent excessive smoke and flare-ups.  Do not allow a
    heavy build-up of soil to accumulate in the oven.
    During the cleaning process, the kitchen should be well
    ventilated to get rid of normal odors associated with cleaning.
    Before Self-Cleaning
    1. Turn off the oven light before cleaning as the light may burn out during the clean cycle.
    2. Remove broiler pan, all pans, and oven racks from the oven.  The oven racks will discolor and may not slide easily after a self-clean cycle if they are not removed.
    3. Clean oven frame, door frame (area outside of gasket, and around the opening in the door gasket) with a nonabrasive
    cleaner such as Bon Ami* or detergent and water.  The self-cleaning process does not clean these areas.  They should be cleaned to prevent soil from baking on during the clean
    cycle.  (The gasket is the seal around the oven door and window.)
    4. To prevent damage, do not clean or rub the gasket around the oven door.  The gasket is designed to seal in heat during the clean cycle.
    5. Wipe up excess grease or spillovers from the oven bottom. This prevents excessive smoking, flare-ups or flaming during the clean cycle.
    6. Wipe up sugary and acidic spillovers such as sweet potatoes, tomato, or milk-based sauces. Porcelain enamel is acid-resistant, not acid-proof.  The porcelain finish may discolor if acidic or sugary spills are not wiped up before a self-clean cycle.
    Important:
    • Oven temperature must be below 400° F to program a clean cycle.
    Only one oven can be cleaned at a time.
    • Both oven doors lock when either oven is being cleaned.
    To set Self-Clean:
    1. Close the oven door.
    2. Press the Clean pad.
        • CLEAN flashes.
        • SET and UPPER or LOWER flash in the display.
    3. Press the Autoset pad.
        • “MEd” (Medium Soil, 3 hours) is displayed.
    4. Press the Autoset pad to scroll through the self-cleaning settings.
         “HVy” (Heavy Soil, 4 hours)
         “MEd” (Medium soil, 3 hours)
         “LITE” ( Light Soil, 2 hours)
    Choosing the soil level of the oven automatically programs the self-cleaning time.
    5. After four seconds, the oven will start cleaning.
        • If the door is not closed, beeps will sound and ‘door’ will display.         If the door is not closed within 30 seconds, the self-cleaning       operation will be canceled and the display will return to the time of day.
        • CLEAN will appear in the display.
        • LOCK will flash in the display.  Once the door locks, LOCK will
          remain steady.
        • The cleaning time will start counting down in the display.
    Nov 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
    Bosch 24 in. SHX36L05UC Stainless Steel Built-in Dishwasher Logo
    29 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
