Question about Emprex LM2201 22" LCD Monitor
Screen is black power on for emprex monitor LE 1708
5 Suggested Answers
  • 82 Answers
SOURCE: my emprex monitor has power but the image wont
This sounds like a backlight problem. I've had this with an acer laptop before and it needed a new backlight replacment under warranty.
Also check things like the connection cable, try it with a different pc, try a different (lower) screen resolution in case it's not compatible.
Posted on Nov 08, 2009
  • 80 Answers
SOURCE: Monitor is blinking and then went blank
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Posted on May 15, 2010
paulbtorrent
  • 34 Answers
SOURCE: Emprex monitor lm 1905 - blacks out after a
see repair emprex ebay item 300447533053, one was a weak back light needed replacing, test by using 3 out 4 with a spare to make the 4 out of 4 (if you have two lcd, just disconnect one panel completely and link 1 into the other inverter without dissassembling the pannel ! ie [=i=] - [==] to find or see if back lights, it's a bit young for the capacitors to go (1 or 2 years) , else over heating , try out of case on a plastic sheet or similar for the pcb side to rest on reassembled, I used this plus tape stuck it on the back of the pannel ie pannel, plastic sheet pcb's then power and vga connected , solved an over heating on a 2year emprex , LCD as just 3 parts and the casing, ps the high voltage parts with shock your hands don't touch when switch on!
5 times later still getting shocked, reaching in to adjust the vga ribbon!!!
Posted on Jul 18, 2010
  • 161 Answers
SOURCE: I bought my emprex monitor
Yes it can be repaired usually just easier to by a new one. it sounds to me like it is a power supply for the monitor. The only hard thing would be getting the power supply for the monitor. Your can try contacting the manufacturer for it :) hop this helps
Posted on Dec 27, 2010
I bought my emprex monitor 3 yrs back. For all these years it had worked its best. But now, when the computer is powered on, the screen flickers by producing small poping sound and goes black...please...
Dec 27, 2010 | Emprex LM2201 22" LCD Monitor
Vertical lines on my Emprex 32" monitor
That menas you have failing T0con BOARD, part of the LCD panel assembly, not much you can do, new LCD panel needed, it will get worst.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 16, 2010 | Emprex LM2201 22" LCD Monitor
Good Luck!
May 12, 2010 | Emprex LM2201 22" LCD Monitor
Monitor keeps going into standy and i cant get it back on. It works for a short while, then the screen goes black and the standby light comes on. It wont come back on.
Common failure in LCD monitors are due to bad caps in the power supply/inverter board, that will be the first place to check. Please see my albums so you will know what to look for inside.
http://www.badcaps.net
Bad caps:
Apr 22, 2010 | Emprex LM2201 22" LCD Monitor
If this has an internal power supply (no external brick) then you probably have failure of the capacitors inside. The problems exhibited by these failures are usually summed up as "works for a short while and quits" or "will not come on". Yours is probably similar to some Gateway monitors that I have repaired, The parts required for the repair should be under $10.00 and should take under an hour. Now you need to find a shop that can and will do the work unless you have soldering skills.
Dec 05, 2009 | Emprex Computers & Internet
My emprex monitor has power but the image wont stay on. the screen somes on, shows an image for about 2 seconds then goes black.
Nov 08, 2009 | Emprex LM2201 22" LCD Monitor
Screen resolution
you adjust high resulition so monitor always black' 1/ for solution you can reinstall computer 2/ from f8 you can re adujst resolution.3/u can use cd operating tools as erdcommander 2005. whiich help to chang hard drive data from cd.
Jun 09, 2009 | Emprex LM1704 17" Monitor
There are 2 inches of black space on both sides of my screen.
There should be a way to go into the screen settings on the set (either from the remote or on the bottom of the screen). From that menu you can adjust the size of the screen, stretch it, align it, etc.
May 04, 2009 | Emprex LM2201 22" LCD Monitor
Emprex LM2201 22" LCD Monitor Logo
325 people viewed this question
Top Emprex Computers & Internet Experts
David Payne
David Payne
Are you an Emprex Computer and Internet Expert? Answer questions, earn points and help others
