Question about Crosman Optics
Barrel will not stay open when broken for loading. Springs back violently. Also barrel points upward after loading. Gun shoots too high to use open sights
    President:
  • 2,702 Answers
Bad triger,,,getb it fixed,,,as for the bent barrel they bend if you let them spring back a lot!
Posted on Sep 06, 2010
Assassins creed 3 at one point wont let me select gun when that is what i need
I had the same problem as you. All you have to do is place your curser over the red barrels and then it will allow you to shoot.
Nov 03, 2012 | Microsoft Xbox 360 Console
Why my crosman recruit .177 shoots inconsistently?
I hear that the ammo has alot to do with that. .BB on a unrifled barrel gun are not as good as pellets. Lead pellets ride on the rifling in the barrel. And also your sites could be out of line. One man took the inner barrel out of the outer barrel and bent it over his knee slighty.His rifle was shooting high. On his daisy model # 880 Powerline.. But I would not go that far.A unrifled barrel is best for BB's.only.Hope I can help you out.Yours truly Joseph Alexander Bagli.
Jul 10, 2012 | Crosman Recruit Multi-Pump .177 caliber...
I have a bushnell elite 4200 mildot you can get it 0 perfect shoot 3 to7 times it will move 1 to 2 inches left or right up and down stay perfect. gun has a fixed front bypod and fixed rear adj. rest...
Not sure what your asking, but I will try to explain what I think is going on. If you fire the gun cold (one or two shots) and you are on target or zeroed in. Then the more you shot, the point of impact wanders off center or gets worse. This can be caused by the receiver getting hot (warm) from firing, and tweaking the scope in the rings enough to move it. Another reason can be the bullets you are using Then also through a hot (warm) barrel. Bullets stringing or shot placement going up / down can be attributed to the hot (warm) barrel. As the barrel gets warm the diameter increases and gas from the powder will escape around the bullet in the bore and cause flame cutting. Flame cutting can/ will cause a decrease in muzzle velocity, which will string the bullets in a vertical line out at target range. Horizontal bullet placement is caused by sight errors (scope moving) or movement of the gun in the shooters rest, called flinching, or "pulling" as the shooter expects the gun to go off. One way to find out if this is what is happing, is to have a friend load the gun or not load the gun (single rounds) and hand it to you to fire. if your friend does not load it and you flinch thinking shes about to go off you have to work on that aspect of your control. Once you have that control issue out of the way you will see a huge improvement in your shot placement.Hope this helps Fix Ya up.
Apr 05, 2011 | Bushnell Elite 4200 6-24x40 Riflescope...
How do you load crosman quest 1000. never owned a break barrel gun before
You load one pellet at a time when the barrel is broken open, the chamber is in the break of the barrel. One stroke, load, close, shoot, keeps you in shape. the old Sheridans, 10 pumps, really kept you in shape.
Aug 12, 2010 | Crosman ® Quest cal. Air Rifle with 4x32...
Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
Apr 05, 2009 | Toys
My daisy model 99 bb gun does not shoot bb's with any force.
Try shooting a ton of silicone oil into the oil hole on the side of the barrel and then leave the gun sitting on its muzzle over night, then in the morning with the barrel out dry fire it a couple of times and then try it. what this does is expand the leather seal and bring back air pressure. it worked on my 99, good luck
Mar 23, 2009 | Sport & Outdoor - Others
My Sanyo 1000W microwave is shooting sparks!!!
you need to replace the cavity cover "the cardboard like",the antenna bearing set "the gun barrel like" and the gear motor.If the "gun barrel like" is stuck up because the gear motor is not rotating excessive heat will occur inside the microwave thus burning the cavity cover.
Mar 20, 2009 | Sanyo EM-A5200SW Microwave Oven
Gun will not ****, only shot three times
Are you trying to say it will not c.o.c.k.? (dang sensors.) If so, you have to slap the barrel pretty hard toward the front or tip of it. Hold gun firmly and bang that barrel good with the palm of your hand. It should then break open the barrel and be ready to load and shoot again.
Mar 15, 2009 | Crosman ® Quest cal. Air Rifle with 4x32...
Remington 1100 12 gage won't load a shell from the magazine
Are you shooting very light load?
Have you tried different ammo?
Light loads may not produce enough energy to work the action properly.
If different ammo doesn't help, make sure the two holes inside the barrel ring are clean and gas from the barrel can pass through. Next I would check the o-ring for cracks. If you shoot lots of shells (competition clays) the recoil springs inside the stock or over the magazine tube may have become weak and need replacing.
Jan 12, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Optics Logo
125 people viewed this question
Top Crosman Optics Experts
Anthony Coots
Anthony Coots
Level 1 Expert
raysaw
Are you a Crosman Optic Expert? Answer questions, earn points and help others
