Question about Field and Stream F13PKTPK Pocketwatch
I replaced the battery and can't get the back plate back on the watch, what am I doing wrong
  • rch219 Sep 02, 2010
    I kept experimenting with trying to get the back on and finally took it out to my workshop and put it in a vice with a soft paper padding to cover the watch. After aligning the slot that goes over the internal stem I squeezed it shut from the bottom; this resulted in the top near the stem creating a slight gap. I took a small C-clamp and put just enough pressure near the stem and on the top of the watch for it to close and engage the back to the watch completely. It worked but I used a great deal of caution in doing this, being very careful to make sure the stem slot was aligned and that I did not exert too much pressure, just enough to see and hear it snap together.
    Thanks for the response, and I wouldn't recommend my fix to anyone unless they have the right tools; a small vice and small c-clamp, and a great deal of patience. I also would not recommend this watch, it looks good and it, works fine, but maintaining it is a frustration waiting to happen.
  • 831 Answers
Thank you for contacting FixYa.
Hmmm I dont know if you are doing anything"wrong". It really is difficult to determine not knowing the watch. I would try to take to a local jeweler to have them take a look first. They may be able to assist you.
For more info, check out this link:
https://home.comcast.net/~k_singer/Opening_Pocket_Watch_Cases__k.htm
Best regards, Jewel
Posted on Sep 02, 2010
5 Suggested Answers
  • 12 Answers
SOURCE: What do you use to snap on the back plate of a wristwatch
Tools are available from many watch suppliers, one is Jules Borel, jborel.com, best to get a new gasket and mabey a spare if you wear this in the water then a new crown or crown seal also.
Posted on Jun 14, 2009
SOURCE: watch
I would recommend you to go to a Juwelry, or a watchmaker and let him put the plate back on it. They might do it for free, or it will cost you 3-5 euros/dollars, nothing much;)
Posted on Jun 26, 2009
SOURCE: Can't get the back plate of a Timex Indiglo WR30M watch back on
To open watch case, hold back of watch up with arrow pointer on the back plate pointing to the right. There is a pry point on the upper edge where you will see a small arrow pointing. Use a small flat end screw driver to pry the watch case open. Be sure to replace the back the same way with the arrow pointing away from the setting knob.
Take a 1-1/4 inch paddle bit and drill a hole in a 1-3/4 inch wide piece of wood about 1/8 inch deep. Then take another piece of wood about 2 inches long by 3/4 inch thick by 1 inch wide to lay across the back of the case plate. Place the crystal of the watch in the drilled hole. Used a vise or clamp with the watch between the two blocks of wood to press the back on. Be careful not to over press. Works great
Posted on Jun 05, 2010
  • 2501 Answers
SOURCE: replacing the back on a KC3556 kenneth cole wrist watch
I suggest you contact the maker by going to their web site http://www.genevawatchgroup.com/ (this is the maker) and speaking to them. You are not the first to have this kind of problem and they should be able to sort it out for you.
Posted on Jul 15, 2010
Can't get Casio Futurist into vibrate mode since reoplacing the battery. The "VIB" area on the watch won't flash for me to adjust the setting. Am i doing something wrong or simply goin
2 things you could have the back on wrong way or you've lost the small coil spring that touches the back plate of the watch that give you the vibration ,,
Nov 22, 2014 | Casio Futurist Mens Vibrating Alarm Watch...
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    Battery replacement
    Hi.
    Battery replacement is done removing the back plate. The back plate is uncrewed clasping it with a special tools and rotating anti-clockwise. In absence of the special tool a common pair of tweezers will do the job.
    Once the back plate is off, extreme care must be taken with the rubber seal, running around the edge of the case opening. This is very delicate, and damaging or kinking the seal may result in the watch loosing its water proof capacity. For this reason battery replacement is better done at the shop.
    Here casio page for this model:AMW320R-
    Sep 28, 2010 | Casio AMW320R 1EV Casual Sports Watch
    How to change battery
  • Spread the towel out on a flat surface.
  • Remove the watchband if necessary in order to access the back of the watch.
  • Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.
  • Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.
  • Remove the rubber protector to find the battery.
  • Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.
  • Remove the old battery with tweezers.
  • Insert New Battery and Reassemble Watch
  • Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.
  • Replace the clasp over the top of the new battery.
  • Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.
  • Replace the rubber cover.
  • Replace the back plate by screwing the small screws back into place.
  • Replace the back protector by screwing the small screws back into place.
  • Reattach the watch band to the watch face.
  • Feel a bit unnerved by this? Find a local jeweler. Best regards.
    Jewel
    Sep 01, 2010 | Casio MTP3036A-2AV Wrist Watch
    Battery replacement procedure for Casio 901 DW-5600?
    hi, if the back plate on the watch the part that is against your wrist has four screws holding the silver back plate onto the actual watch then you need to undo these four screw, once undone you lift the back plate off and then this gives you access to the battery, the screws are small philips (cross head screw) so you will need a small screw driver, their is also a little bracket that holds the battery in place you can either push this over to allow the battery out or undo the small screw that holds this bracket in place this will then allow the battery to fall out,
    If their are no screws in the back plate then all you need to do is get a very fine flat head screwdriver and look around the edge of the back plate and you should see a little bit on one of the edges that allows you to put a screwdriver into to allow you to lever the back plate off if it has no screws then its just a push fit so just pry the back off and this will give you access to the battery then like above the battery will be held in place by small bracket undo this then remove the battery.
    when fitting the new battery make sure you dont touch the top and bottom of the battery as this will flatten it really quick so just push it in place then refit the bracket then either push the back plate back on or screw it back on depending on the type of back plate once this is done you watch will be working again
    Aug 14, 2010 | Casio DW-5600E-1VCT Wrist Watch
    Watch
    Jun 26, 2009 | Watches
    Jun 11, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
    Timex Sleek stopped beeping when I replaced the battery
    This is a common problem when non watch educated people are changing battries themselves.
    The answer is simple: While changing battery and handling the watch you did lost the coil spring. It is so small, you will never notice that the something was dropped.
    Coilspring is the connector to the sound membrane of the watch, transfering microprocessor signals to audible membrane.
    If it's lost, there is no connection between watch movement and audio membrane.
    I suggest that you did change batteries yourself previously and had the same outcome (no sound). Next time you gonna change the battery - make sure you do not turn the watch upside down and if you do - check the movement with eyeglass and make sure all the loose fitted bits are in place.
    To get your both watches fixed visit your nearest watch repair shop and ask for coilspring to be fitted.
    Rate me, please.
    Mar 26, 2009 | Timex Ironman 30-lap, Blue And Silver From...
    Phillipe Stark PH1079 watch - Can't get back off to replace bat
    There is nothing wrong with your watch. The problem is in tools the jewellers are using for opening the watch.
    Despite being under one roof, watchmaking and jewellery are completely different trades and are miles apart. Jewellers usually are equipped with very basic watch repair tools and the case openers are no exeption.
    You have to find your nearest watch repair shop and ask for watchmaker, not jeweller. Any decent watchmaker will have the right tool to open your watch and replace the battery in a matter of minutes.
    Do not forget to rate, please.
    Jan 14, 2009 | Fossil Philippe Starck PH1035 Wrist Watch
    Sekonda 3850 battery replacement
    Hi, its Richard, after battery replacement before replacing watch back, there is a small hole in the movement near the edge if you look down it there is a metal plate at the bottom gently press this with a fine screwdriver, the display will then come on, it is a reset switch, regards Richard.
    Aug 20, 2008 | Watches
    Field and Stream F13PKTPK Pocketwatch Logo
    230 people viewed this question
    Top Field and Stream Watches Experts
    Joe Ball
    Joe Ball
    Are you a Field and Stream Watch Expert? Answer questions, earn points and help others
