Question about Marshall MXL-V69-MEDT Microphone
Someone dropped my mxl v69 medt and bent the gold grill but did not damage the mic it still works can i replace the grill or how do i disassemble the grill in order to bend it back into shape if possible
    New Friend:
  • 151 Answers
Very delicate work.
Take it to a Watchmaker ot a good tech.
Do NOT clean with alcohol or any solvent !
I would say bring it over, I do these things, but I am in Caracas...
Peace-
Posted on Jul 18, 2016
2 Suggested Answers
  • 1137 Answers
SOURCE: I have a MXL 990 studio mic which I recorded one no longerworks
Are you using the original cable for the mike? In order to use phantom power the XLR connectors have to be wired in balanced configuration. Pins 1,2 and 3 must be wired separately. If you use a cable with 1and 3 connected you could damage the phantom power supply and in some cases the microphone.
Posted on Aug 20, 2009
Mxl 40000: When you plug it in it works for a split second and then volumn drops to almost zero.
Sounds like a weak or missing Phantom Power Supply. This power is supplied by the source "mixing console" and can be turned off on many models of consoles. If you have a smaller and lower end mixer it is possible it does not provide the needed Phantom Power. Also if the mic cable is incorrectly wired the Phantom Power is not being properly supplied to the mic. This also could damage the mic by putting the voltage on the wrong pin connections. Pin 1 is ground, pins 2 and 3 are audio high and low. Sorry I do know the exact connection for 2 and 3. The user/owners manual may supply the correct wiring information. A store bought cable of good quality should already be wired correctly.
Dec 23, 2013 | MXL 4000 Microphone
990 mxl condenser mic rattles
Not supposed to rattle. Sounds like it may have been dropped. Very delicate parts inside these comdenser mics. Even blowing into them can damage them. Maybe you could get luck to find a screw that vibrated lose if you carefully disassemble the unit. Or you can take it to your local music store/ electronics repair shop and have them repair it.
May 27, 2012 | MXL 990s Professional Microphone
Help...my mxl v69 vac tube mic records well until the end of a song that has a sustained ending. Like it will record an open chord strum, but as the sound of the acoustic guitar starts fading away the mic...
I would see if the Phantom Power is OK.
Check with a voltmeter between pins 2 & 3 on the feed cable.
Should be around 40 Volts.
If not, check it on another mixer.
Now you know.
Peace-
Nov 27, 2011 | Marshall MXL-V69-MEDT Microphone
My mic has a very nasty hum please help!!!! I've had it for 7years now and it has never done this b4 so i really need help.
Open up carefully.
Something came loose on the ground cables or the chassis inside.
Tighten screws, check cables, and connectors.
Peace-
Jul 21, 2011 | Marshall MXL-V69-MEDT Microphone
I've had a Marshall MXL 2001 mic for seven or eight years, and it's worked without a problem. Yesterday, it stopped working. I opened it and don't see any loose wires. Where should I take it for repairs?
mics are very delicate . a lot bundled into a small area. If you are handy..take it apart. All you may be able to do is check for loose solder joints..mics are dropped, moved a lot so they go through a lot of physical stress. My last mic repair ended up being a bunch of loose solder connections. if not..if its of value to you..send it in. Trace Electronicss..Canada.
May 06, 2010 | Marshall MXL 2001-P Professional...
One of the 5 golden pins was broken off in the
The v-69 is a tube condenser. We here at Pro Line Music are MXL Dealers. If you can get the mic to us we can repair it 215-736-8055
Dec 29, 2009 | Marshall MXL-V69-MEDT Microphone
Aug 19, 2009 | Marshall MXL990 Professional Microphone
MXL 990 doesn't work
Your other preamp does not have phantom power to supply power to the microphone. All condensor mics like this need phantom power. The Audio Buddy provides phantom power, which is why it was shipped with those condensor mics
Jan 16, 2009 | M-Audio MXL 990/991 Recording Mic Duo and...
Stopped Working
cables,phantom or connectors
Aug 20, 2007 | Marshall MXL-V69-MEDT Microphone
Marshall MXL-V69-MEDT Microphone Logo
208 people viewed this question
Top Marshall Audio Players & Recorders Experts
Tom Chichester
Vito Vacirca Jr.
Jerry Kramer
Jerry Kramer
Are you a Marshall Audio Player and Recorder Expert? Answer questions, earn points and help others
