Question about Steinberg Cubase SX3
Cubase REcording/Playback Problems
Hello:
I am having trouble with Cubase SX. Intermittingly the audio will cut out on recording or playback. I am running Cubase SX via Presonus Firewire on a Dell Laptop 5150. I have 1.5 gigs of memory and an internal 80 GB and external 200 GB HD.
What is causing this problem? How can it be resolved? Thanks.
Jeff Lehman
jjleh@aol.com
    Problem Solver:
  • 4 Answers
Check first the sample rate maybe its to high like instead of 44k. its in 48 96 or something like that so the buffering isnt catching with the recoding . alogn with your lattency configuration must devices are ok in 512 latency.
and also be shure not to be recording directly to tyour external hard drive
in case of plugin overload issue it would not stop recording suddenly it would slow down first with some crackles and then stop or must shure freeze.
so impretty shure its somethin else.
hope it works
good luck
Posted on Jul 26, 2008
Why carn,t i record in cubase sx3,? when i press record i just get the box with no audio?
Posted on Oct 27, 2008
  • 3 Answers
I was having the same problem with an old Sound Blaster Live audio card. When I was exporting, there would be sound-blank-sound-blank.. etc. The problem was that it could not handle all the effects and plug-ins. It was a Multimedia ASIO driver (software). So, I will guess that either the audio card cannot handle ASIO drivers HARDWARE, either the driver in the devices menu is not set to hardware, and it runs on software ASIO. If your card cannot support hardware ASIO, then you must work with low sample rate (44100) and almost no effects. VST instruments will also have much latency.
Posted on Jun 05, 2008
Bush dvr3006 will play audio disks but wont play any dvd ! just says load for ages then turns off or no disk ! help please ?
These are the formats your DVR will or will not play.
  • Blu Ray Playback: No
  • Blu Ray Recording: No
  • Compact Flash Card: No
  • DTS Decoder: No
  • DVB-C: No
  • DVB-S: No
  • DVB-T: No
  • DVD Audio Playback: No
  • DVD Player / Recorder: DVD Recorder
  • DVD+R Playback: Yes
  • DVD+R Recording: Yes
  • DVD+RW Playback: Yes
  • DVD+RW Recording: Yes
  • DVD-R Playback: Yes
  • DVD-R Recording: Yes
  • DVD-RAM Playback: No
  • DVD-RAM Recording: No
  • DVD-RW Playback: Yes
  • DVD-RW Recording: Yes
  • DVI Interface: No
  • DivX Playback: No
  • Double Layer Recording: No
  • Electronic Program Guide (EPG): No
  • Ethernet: No
  • Firewire IEEE-1394 Interface: No
  • HD-DVD Playback: No
  • HD-DVD Recording: No
  • HDMI Interface: No
  • HDTV: No
  • IPTV (Internet Protocol Television): No
  • Integrated VCR: No
  • MP3 Recording: No
  • MPEG4 Recording: No
  • Memory Stick: No
  • Multimedia Card: No
  • Number of Scart Interfaces: 1
  • PCMCIA Interface: No
  • Progressive Scan: No
  • Real Dolby: AC3
  • Secure Digital Card: No
  • Show View: No
  • Smart Media Card: No
  • Super Audio CD Playback: No
  • Super Video CD / Video CD Playback: No
  • Table / Portable: Table
  • USB Interface: No
  • W-LAN Connection: No
  • xD-Picture Card: N
May 24, 2014 | Televison & Video
Further clarification is that alyhough i can download the drivers and get playback I can't find anywhere that will download the cubase software to allow recording and sequencing etc on my lexicon lambda as...
It looks like you are trying to download Cubase from Lexicon site . .
You can use any software . .
Here is a link for free Audio Recording Software.
http://audacity.sourceforge.net/download/
Or you can buy a new license for Cubase . .
All the best . .
Sep 13, 2013 | Steinberg Cubase Studio 4 Full Version for...
When i import an instrumental into cubase it will playback but will be very distorted, if i change the device settings in cubase and dont use the io2 it will playback fine so im assuming its something to...
In order for an imported file to sound correctly in Cubase, the bit rate and KHz must be the same or you will create garbage when going through your interface. For instance if you have ripped something from a CD it will be in 16 bit 44.1 KHz format. If you were to pull this into Cubase at 24 bit with 48 KHz selected as your projects rate you would encounter this problem. (I'm guessing this is what is causing your problem.)
Please open up cubase and click import, a window should pop up asking if you want to convert formats, please select the check boxes for conversion for the bit rate and KHz (depending on what version of Cubase it will be something similar to this.) An alternate solution is to go to the project preferences and select the rates that match the imported material before importing and no conversion will be necessary. (Although, I recommend always working in 24 bit and 48 KHz if you're machine can handle it.) A final possibility is that you have the latency set really low and the converters can't handle the speed at which the information is being processed. If the above should for some reason not work, check in your preferences box in Cubase if possible or through software that came with your interface and increase the latency. This can cause an audible delay between the time you hit a note and hear it back so make sure to decrease it before recording and increase it while mixing since you won't being recording new material and can use that processing power that would have gone to making sure you hear your live audio quickly can be steered to use plug-ins and get crackling free playback. Remember, with latency, even if get crackling from a low latency you will not hear that crackling upon mixdown! However, I'm quite sure your problem is with conversion rates, but if never hurts to know or get a reminder on things like latency. Cubase is a high quality product and I hope you enjoy using it. Thank you and I hope this helps.
Feb 25, 2011 | Alesis iO | 2 Sound Card
Crackling and popping during playback/recording, latency issues. Using Firestudio Project, Windows 7 and Cubase 5.
Turn OFF all resource hogs such as Anti-virus, Anti-pop-up, and other background programs. Disconnect all internet access such as wireless and Ethernet service programs. All these resource hogs and programs for instance that keep track of when to run scans just cause interrupts of the servicing of the high speed audio grabbers. Your machine should be BARE of all these hogs.
Feb 23, 2011 | PreSonus Firestudio 2626 26x26 + Cubase...
Problems with yamaha mw10c usb mixing desk i have a signal on desk but cubase is not picking it up and i can find no option in any cubase menu to read the usb audio
Make sure that in the control panel of Windows, "Sounds and Devices" under the "voice and recording" tab, the Yamaha mixer is shown as the device for both voice recording and playback.
Feb 04, 2011 | Yamaha MW10C 10-Channel USB Mixer
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Sep 26, 2008 | Tascam US-144 Sound Card
Playback recordings
Problem with cable? Change in sample rate? Have you changed software/drivers? Could do with more info.
Jan 17, 2008 | Edirol UA-25 External Sound System
Problems recording with Tascam us-122
you dont say what program you are using to record on. If it's cubase sx it's the fault of the program not the soundcard. Contact cubase and they will give you the fix
Jun 02, 2007 | Tascam US-122 USB Audio/MIDI Interface...
Open Questions:
See all Steinberg Cubase SX3 Questions
Computers & Internet Logo
625 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Donald Currie III
Level 1 Expert
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
