Question about GPS
Code Alarm 2-Way LCD Remote ELVNTRCA (LCD) - GPS
2001 maxima alarm not working but panic works
ck for a fuse in the under the hood fuse box that says bsm may be blown.
Also try this.....
To reset the security system remove the negative battery cable for 30 minutes, then reconnect the cable. Next, lock and unlock the doors using the remote. This will reset the alarm system and the engine will start and fobs reset.
Here are some factory notes....FYI
Anti-Theft Systems
PROGRAMMING
NOTE: If a new Smart Entrance Control Module (SECU) is installed, a new identity code must be entered and all remote controllers must be programmed. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
PROGRAMMING > PROGRAMING NEW ID CODE
NOTE: This procedure will erase all previous identity codes and render all previously programmed remote controllers inoperative (until reprogrammed). All remote controllers to be used with system must be programmed at the same time. A maximum of 4 remote controllers can be programmed. Any attempt to program more than 4 controllers will be ignored. If same identity code is entered more than once, entry is ignored even though hazard warning lights will still flash twice.
1. Close and lock all doors. Erase original identity code(s) by inserting and completely removing key from ignition switch more than 6 times within 10 seconds. Hazard warning lights should flash twice. Turn ignition switch to ACC position.
2. Push any button on new remote controller once. Hazard warning lights should flash twice, indicating identity code has been entered. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
3. For each additional remote controller to be programmed, manually release door lock and lock again by using door panel switch and repeat step 2. If no additional remote controllers are to be used, exit programming mode by unlocking and opening driver's door.
Please let me know if you need anything else to get the problem fixed. Happy mew Year!
Jan 03, 2018 | 2001 Nissan Maxima
My autopage rs 727 lcd is not starting in remote start, it is only cranking
what kind of vehicle? it is most likely a transponder or theft system bypass problem, since it is trying to crank.
Feb 12, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
Do you know the remote code for LCD TV "Soniq" QSL322T
The remote you refer to is for controlling a car alarm not a television!
Please post the model number of a TV remote control you want to program and I can hopefully find a code for the QSL322T
Oct 15, 2010 | Directed 434MHZ Remote Control
I have a viper 5501 LC3 SST LCD alarm; my problem is the door open sign goes on, when the doors are well closed! help me please! thanks!
This sounds like you have a delay domelight and they used that to trigger the alarm. You domelight stays on for 20 seconds after you close the door so because it is still on the alarm thinks the door is open even if the doors are closed. you can fix that by having a tech hook up the door triggers to the door latch wires and not the domelight itself...or you can program the alarm in Menu 2 otion 3 to not sense the door ajar when you first arm your alarm.
Sep 29, 2010 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
I have an ungo remote start/alarm. This AM the car would not start and the alarm went haywire- kept going off, took control of the car, A/C going on and off, etc. Had to disconnect the battery to get it to...
i have a ungo sr 6000 i missed placed my lcd 2-way remote so i only have the secondary 4- button remote. How can i disable the timer auto start!!!!!!!!! PLEASE HELP ASAP !!!!!!!!! GOIN BROKE ON WASTED GASSS!!!!!!!!!!!!!!
Jul 30, 2010 | Ungo SR6000 2 Way Security with Remote...
Need installation manual for motorjoy 2 way alarm
What kind of alarm? and do not take it to a mechanic take it to an audio shop they should be more trained in doing remote starts
Jun 11, 2009 | Vehicle Parts & Accessories
I need remote code for Mintek LCD model 260
Use toshiba code 0156 that should turn on the mintek tv on
Jan 01, 2009 | Mintek DTV-263 26 in. LCD Television
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
GPS Logo
117 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
