Question about Alpine CDA-9851 CD Player
Hooking it up in a 1998 ford explorer and need wire diagram so i know how to hook up factory amp because stock cd player sounds better than eclipse.
  • 15,935 Answers
CLICK HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 02, 2010
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
My 1998 land rover discovery i replaced the stock cd player with a pionner after market cd player everything is hooked up properly but cant get sound
Oh... Pioneer may be bad. I had a new tape player that was broken the day I bought it. Pioneer did replace it.
Apr 28, 2013 | Cars & Trucks
How do i hook up my car speakers to an aftermarket cd play in a 98 ford explorer
Is the CD player independent of the tuner or is this an all in one unit.
Jan 29, 2013 | Car Audio & Video
I installed my cd player but it only plays the radio does play cd's
by "play" im assuming u mean no audio... check the wires, in the back there should be 2 blue wires, one has a white stripe... splice them together or reverse them... it sounds like you have it hooked up to the power antenna wire (should be solid blue wire) is sending power for the amp to turn on only when the fm is playing... you want the amp turn on wire (blue with a white stripe) to be hooked to that factory wires so when the radio is on your factory amp is triggered... if that doesn't work let me know there are other thing you can try...
May 02, 2010 | Eclipse CD2000 CD Player
Stereo system in 1994 ford explorer
I had this same problem.Took it to a friend and we bypassed the amp completely and ran new wires to all the speakers.
Aug 25, 2009 | Dual XDMR7710 CD Player
Pioneer dehp3100ub.stock speakers wont work with unit?
If the vehicle has a premium sound package - you need to use the remote wire to turn on the factiry amplifier.
If you want to use the power from the radio for the speakers, you must buy and install a factory amplifier bypass harness.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 19, 2009 | Pioneer DEH-P3600 CD Player
Car Door Speakers wont work after installing new Stereo
check you Fade and Balance,sometime the ground is used for two speakers sometimes a ground is used more then once will cause your problem ........Good luck......
May 14, 2009 | 1998 Ford Explorer
Stock Speakers wont work with new stereo plzzzz HELP
U have a Factory audio auxiliary amp in the truck, the radio is just a head unit with a preamp feeding a main amp, that is behind the right rear 1/4 panel trim panel in the cargo area, if your new sound unit has preamp outputs use them, other wise u must wire around the Ford factory amplifier.
May 13, 2009 | 1991 Ford Tempo 4 Door
New cd player made in china
The yellow wire does not get used unless you have a power antenna to hook it to. The red wire is suppose to be hooked to the wire that was used as power for the stock stereo, so it turns on and off with the key. If you have it hooked to constant power, it has power coming to it even when it's turned off. That and the fact that you may need a better ground is most likely the reason you're getting the moise even when turned off. You may also want to check your speaker connections.
Oct 08, 2008 | 1993 Ford Explorer Limited
No output when I play a CD
what kind of vehicle do you have? i am going to guess your vehicle has a stock amp that it uses to power your speakers? you will have to hook up the remote wire for the amp to the wire that powers the amp in your vehicle (the stock amp) right now it seems like you have the "power antenna" wire hooked up to the stock amp in your vehicle.
Aug 24, 2007 | Eclipse CD7000 CD Player
Alpine CDA-9851 CD Player Logo
193 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
