Question about Garmin nuvi 255W GPS Receiver
The screen of my Garmin nuvi 255w gps is white and says "press dot" in the lower left hand corner but when you press dot nothing happens
  • 3 more comments
  • jeasteagle Sep 02, 2010
    this didnt work held lower right corner for 10 minutes nothing happened
    that didnt work held the lower right corner of the screen for 10 minutes and nothing
    the only thing that happens as i turn the unit on while holding the lower right corner of the screen is the press dot moves to the top center of the screen im not getting any other message other then the white screen press dot and there is no reset button anywhere on the divice that i can see
    im about ready to give up on this thing..it has no reset and holding the screen isnt working
    the only way to get to the battery is to take the unit apart and its two very small screws that look like torque screws....
  • 4,924 Answers
I think that you will have to make a total reset in this unit to make it functional ..but keep in mind that this will erase all data on it and you will have to reconfigure it again ..
Here is the procedure ..I left it like it was in the tutorial cause one never knows exactly how it will behave ..and they have more than one way to do that ..I suggest that the last one will work ..
In the Quick Start Manual of Garmin Nuvi 255w GPS, it stated that you can reset the unit by pressing the RESET button at its bottom. However, the RESET button is not found in my Nuvi 255w.
Additional information in the Owner's Manual stated that if RESET button is not found, slide the POWER key and hold it for more than 8 seconds will do the same, but I found out doing so will go to the touch screen calibration utility instead.
Another section in the Owner's Manual under the title "Clearing User Data" stated that holding your finger on the lower-right corner of the screen while turning on the unit and keeping the finger pressed until a message appear, that will allow you to delete all user-entered information.
I tried it and a message window pops up asking about "Do you really want to erase all user data?". There are 2 buttons to select, Yes or No. If you want to try this, make sure you've backup the data in your unit before answering to Yes.
Posted on Sep 02, 2010
  • 2 more comments
  • Catalin Turcu
    Catalin Turcu Sep 02, 2010
    it supposed to keep the corner pressed and turn it on ..from the power button ..and after that the asking message will appear..
  • Catalin Turcu
    BY the way ..if your model have a reset button use it ..some of those models have ,,it is somewhere on the bottom I think ..in case it is any ..
  • Catalin Turcu
    try to remove the battery and see what happens ..this reset thing it supposed to be working ..if it is not ..than it might be something wrong with the firmware ..and probably will need to download update and reinstall it ..(update firmware )
    http://www8.garmin.com/products/webupdat...
  • Catalin Turcu
    http://www8.garmin.com/manuals/2675_Owne...
    this is teh manual ..and all I already said is on the page 42 ...if you tae a look you will see that you do not have other options if the resetting will not work ..but try to download teh updater and take a chance ..I understood that this software will recognize it and will make things almost auto ..
Garmin nuvi 205w gps black dot problem
Please be more specific. There is a calibration screen where black dots are shown and you press them to calibrate the touchscreen. Is this what you mean? If you press them and nothing happens, your touchscreen may have failed and needs to be replaced.
May 27, 2013 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 255w flashes on & off
I did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars
Apr 02, 2013 | Garmin nuvi GPS
How to calibrae my gps nuvi garmin 255????????????????
For the Garmin 2x5 series GPS
Calibrating the Screen:
1. Turn off the nüvi.
2. Hold the upper-left comer of the screen white turning on the nüvi
3. Release the power key when the Garmin screen appears.
4. Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
Here are links to the manual for both the 255 and the 255W (wide).
I hope helped & good luck! Please rate my reply. Thank you.
Jun 30, 2011 | Garmin nuvi 255W GPS Receiver
I need to calibrate my Garmin Nuvi 1260T. It's been alittle off ever since I got it. I tried holding the power button for 30 seconds and waiting until the calibration screen pops up but nothing pops up. ...
In order to calibrate the screen on the Nuvi 1260T, you need to follow these few simple steps.
- Turn off the device
- Hold the upper-left corner of the screen while turning on the device
- Release the power button when the Garmin screen appears
- Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
This should allow you to calibrate the screen. I hope this helps!
Mar 01, 2011 | Garmin nvi 1260T 35 in Car GPS Receiver
Will not turn on
I have a garmin 255W when turning on all itdoes is go to a white screen with black dot thatsay Press dot .It wont turn on how do you fix this
Jan 19, 2010 | Garmin nuvi 255W GPS Receiver
Screen went all white with 'press dot' on bottom left corner
To fix the abnormal behavior of your Garmin Nuvi 255W, I recommend a hard reset and an update of your Nuvi 255W firmware.
I hope that helps.
My screen does not respond to my touch
You need to Calibrate the touch screen.1Turn off the Nuvi. 2 Turn on the Nuvi and hold the Power key to the left for about 30 seconds untill the calibration screen appears (white screen with "Press dot")
Nov 08, 2009 | Garmin nuvi 255W GPS Receiver
Hi every time i hit the w button it shows up as 1.please help mrlake23@aol.com garmin 255w 1q6087034
if the screen is not responding properly you have to recalibrate the screen by holding the power button to the left for 30s or so and following the instructions that appear.(white screen with press dot)
Nov 03, 2009 | Garmin nuvi 255W GPS Receiver
My ? Nuvi 710 GPS froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it...
My ? Nuvi 710 GPSicon1.png froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it restart but still goes back to the same screen Is there any way I can fix this?
Apr 22, 2008 | Garmin GPS
Garmin nuvi 255W GPS Receiver Logo
564 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
