Question about Buck AP Industries Lollipop Crib
Need a refresher on how to lower the mattress height for our second child on the way...
Hi how are you I have a Delta - Navajo 4-in-1 Crib, Natural It was giving to me for my son but its been used and it still fine but now my son is almost 3 and I wanted to convert it to a toddler bed but I...
There should be a small rail that replaces the front side of the crib. It's lower and allows your child to climb in and out of the bed on their own. The mattress support frame will need to be lowered close to the ground so the child can easily and safely climb in and out. I have a different model that I recently converted for my 3 yr old.
Mine looks very similar to this now:
http://www.davincibaby.com/images/products/3613/kalani-crib_white_toddler-bed_angle_2.jpg
Jul 08, 2014 | Baby Gear
Lowering crib mattress
What is the exact make/model of the crib? Did you just purchase it and put it together?
Thanks,
Lee
Jun 17, 2008 | JCPenney Basic Crib
How do I know when to buy a bigger seat or which positions?
His legs bending does not mean that he is too big for the seat. He is too big for the seat when his head reaches one inch from the top of the chair while sitting in it.
Please read the information in these links for further information:
http://www.cpsafety.com/articles/stayrearfacing.aspx
http://www.thecarseatlady.com/
Nov 18, 2012 | Cosco Scenera Convertible Baby Toddler Car...
Do toddler beds need special mattresses?
The only thing you need to check is that the mattress is the right for your toddler bed and that it's appropriate for the weight of your child. Usually toddler beds are only transitional until they move into full beds so I wouldn't worry too much about the mattress. Just make sure it meets safety and fire hazard requirements (check the label attached to the mattress).
Aug 14, 2012 | Baby Gear
How to lower crib mattress on a Pali
The Pali cribs often used a "scissor assembly" spring frame. This means that there are "Y" shaped arms located on each corner. There are holes in the side of the spring frame, you will need to unscrew the bolt and nut and attach them at a different hole to adjust the height.
This is a rather difficult topic to cover in writing. If you would like to see a diagram of how this functions, please email us at parts@productsamerica.com.
Apr 06, 2012 | Pali Baby Gear
Need to lower mattress to lowest posistion, how?
1). remove the mattress, bedding and any load on the mattress spring.
2). remove the bolts attaching the support frame to the crib
3). reattach at the desired level.
4). reattach all 4 points and tighten. Do not overtighten.
5). Replace mattress bedding and any load.
Any further questions? Contact the manufacturer directly. They respondquickly and have the most accurate information for the SAFETY OF YOUR CHILD.
Here is the website for Million Dollar Baby, DaVinci and Babyletto:
https://milliondollarbaby.zendesk.com/home
Apr 04, 2011 | DaVinci Emily Crib
Hi there. i have purchased the frootmuff for quinny and there is no instructions. im not sure where the straps attach to on the top and there is 2 slits for the soulder straps to go through when i can only...
the first large hole to the bottom of the footmuff is for the **** pad you will then need to remove top section of straps from the pram which is a slide clip then remove the strap covers at this point you can push the straps in the two lower slits at about bottom height then you will need to put the strap covers back on then fit through either the first or second slits in the cosey toes (depending on height of child) attching he straps back to the pram and you are ready to go also most quinny prams have 2 levels which the shoulder straps can be attched i hope this helps x
Nov 23, 2009 | Quinny ZAPP Stroller
Can't lower side of GenAmerica drop side crib
You can unscrew the bolts that allow you to separate the metal frame from the rest of the crib. Once separated, you will be able to work with the rest of the bolts.
Jul 09, 2009 | Baby Gear
Childesigns carrollton crib
I am not familiar with this crib, but I have been through many cribs and they all (so far) are adjustable to lower the mattress. You can figure it out by removing the mattress and matress board and inspecting the way the board is connected to the frame. Often there is a bar or rung that sits in a clip or groove at each corner of the crib just below the matress board. You may have to crawl underneath and look up at it. Usually you will be able to lower the platform without using tools, but be sure to take the weight off the platform by removing the mattress and board. Good luck.
Nov 14, 2006 | Childesigns Carrollton Crib
Buck AP Industries Lollipop Crib Logo
104 people viewed this question
Top Buck Baby Gear Experts
Dorel UK
Dorel UK
Bill Boyd
The Audio Lab
Are you a Buck Baby Gear Expert? Answer questions, earn points and help others
