My home theater remote will turn my tv off sometimes and other times it wont work. it is used with a comcast cable box. its worked fine for three years now it doesnt. its driving me crazy
  • 52 Answers
Have you replaced the batteries?
Posted on Sep 02, 2010
HOW DO i CONNECT MY RCA RTD325W SURROUND STYSTEM THROUGH MY COMCAST BOX AND MY TV
Video out on rtd325 to Video in on TV, set tV to correct input source, not red/white cables to Audio or AUX INPUT on the rtd325 and run those to Audio out on the comcast box, set rtd325 to AUX fcuntion when watching comcast
Oct 29, 2013 | RCA Dvd Home Theater System Rtd325w Remote...
How to get my Sony HT-CT60 Sound Bar Home Theater programmed to my GCI Cable remote?
This worked for me, but I have a Comcast Motorola DVD-R:
These are the codes for your SONY SA-CT60 Audio Device. Follow the instructions below to program your remote.
silver_with_red_ok_button-lg.gif Most likely code: 30158
Others to try: 31758, 31759
To program your Comcast remote:
  1. Turn on the TV or other device that you would like to program.
  2. Press the TV button on your remote control.
    NOTE: If you would like to program your remote control to work with a DVD Player, VCR or Audio device press the AUX button.
  3. Press and hold Setup until the red light blinks twice, then release Setup.
  4. Enter the first code for your device listed above. If you perform this procedure correctly, the red light will blink twice.
    NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 4 with a valid code.
  5. Aim the remote control at your device and press Power once (press the Play key for devices that don't have a POWER button). If the TV turns off, make sure that the VOL+/- and Mute buttons also work. If so, you're all set!
  6. If not, repeat these steps using the next manufacturer's code (you may need to try several codes to find the one that works).
Nov 24, 2012 | Sony Audio Players & Recorders
How do i program my comcast remote to my panasonic home theater system? SA-HT740 series
I have the solution! Get comcast to give you the remote with the GREY Ok/Select button. There are codes for this remote that support the Panasonic home theatre in a box. You can go to comcast.com and find the remote manual for this to see it for yourself. I have 3 boxes and just got a new one and was trying to do the same as you. I found the old remote for one of my older cable boxes and switched it out, programmed for the Panasonic and it all works quite well!
Nov 15, 2010 | Panasonic Home Theater System System
How do I hookup LHT854 Theater System to tv if using comcast digital box? DVD player works fine with sound but but no sound if trying to watch tv.
most cable companies will provide you a high def. cable box for no additional cost. swap digital for high def box. run dvd into high def cable box and run hdmi output from cable box to lg input. hope this helps
Feb 01, 2010 | LG LHT854 Theater System
How to connect tv to comcast cable box
If you only have the comcast receiver and a TV, take the input (wire from outside the house or outlet on wall) and screw that onto the input of the comcast receiver. Take another wire (or RCA, component connecters or whatever means the box and TV provides) and go from the output of comcast receiver to the input of the TV. Set the TV input mode (on the TV itself or by the remote) to whatever mode you hooked up the cables to (video 1, aux, video 2, etc) and you should see a picture. From there use the comcast remote to change channel. If you use the round cable (rg56 or rg59) you will not need any other connections between the TV and the box. The video and audio are broadcast on the same line. If you use RCA (yellow red white) connectors, yellow is video, white and red are audio) you will need all three wires from comcast receiver to TV. I hope this helps and good luck!
Nov 18, 2009 | Audio Players & Recorders
Phillips HTS3566D Home Theater/Comcast DVR 3 Device remote
I have the same problem. The only time that I can get it to work is whenever I turn on the cable box the home theater system turns on too. When I use the DVR it will turn it on too and want to play the CD/DVD. I have a Comcast Motorola DCH3416 DVR box.
Apr 03, 2009 | Philips HTS3544/37 Theater System
No sound through Bravia speakers after BOSE removed.
Did you ever have audio through your tv before?
It's likely that your Comcast cable box was connected directly to your Bose system, and not your television.
You'll need to check the connections from your cable box, to your television.
Mar 17, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Bose Cinemate home theatre
The Bose codes for Comcast remotes for both the Cisco (labeled Xfinity) and Scientific Atlanta (labeled Comcast) DVR remotes are 31229 and 31933. 31933 worked with my Bose CineMate Series II
Jan 09, 2008 | Bose Cinemate Digital Home Theater System...
29 people viewed this question
 Grubhead
Grubhead
