Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Need to add obstruction sensors to an older Craftsman Garage door opener that never cam e with them. Is this possible?
    Sergeant:
  • 226 Answers
Generally not. To get the sensors alone would cost very near the price of a new unit equipped with video sensors. You could verify this with Sears.
tom
Posted on Sep 02, 2010
Craftsman 1/2hp garage door opener works fine to open door but to close I have to hold button down. If not, door won't move and lights flash 10 times.
10 flashes mean sensors are obstructed... something is in the way of the door or they are not facing each other. Clear the obstruction or realign the door and it will work.
Aug 27, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Craftsman 1/2 hp garage door opener will start to close and after 2-3 seconds it goes back up and there is no obstruction blocking sensors
you may need to adjust limit switches in back of operator.Most of the time with this problem one of the gears inside the operator has stripped out.
Jan 26, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman garage door opener Model #139.53664SRT that has worked great until recently. When I leave my garage & try to use the keypad or remote after opening the garage door from the inside of...
From the description about the lights which does have a slight affect on their sensitivity suggests the sensor adjustment. The sensors that detects obstructions appear to be out of adjustment.
Check the alignment for proper operation. It may be dust that is obstruction the sensor.
1466178634909-dmbde0w01a5yu2mfdv43xlfn-4-2.jpg hope this helps http://www.searspartsdirect.com/partsdirect/user-manuals/13953975srt1-craftsman-parts-manual
Jun 23, 2017 | Kitchen Ranges
We have a older craftsman door opener and we now need to hold the button to close the door and the car remote dose not work.
Clear any obstruction from between the safety sensors. Loose leaves, trash, and dirt on the lens of the sensor itself are all examples of things that can obstruct the sensor's signal.
  1. Check each sensor for a steady glowing indicator light. If both indicator lights are on, or if one indicator light is flickering, the sensors may be slightly misaligned. To check for misalignment; obstruct the beam of the sensors so that they cannot see each other. When the beam is blocked, the indicator light on one of the two sensors will temporarily go out. This is the receiving sensor. Remove the obstruction and loosen the wing nut on the back of the receiving sensor. Adjust the receiving sensor until the green indicator light goes out, if not already out, then realign until the green light is bright and steady, then retighten the wing nut. This usually takes a couple of attempts before it is back in alignment.
  2. If an indicator light is out on one or both sensors, check for a possible loose or shorted wire. Sensor wires are attached to the white and black terminals on the back or side panel of the overhead motor unit. Check that they are securely connected to each terminal. Also check the wires for any breaks, especially anywhere they are spliced together.
Jan 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't close. travels 6-8 in.,
If you cannot get the light on the sensor to come on by tweaking it,making sure it is pointed at the other sensor and your wiring is not broken or shorted then your sensors need to be replaced.
Jan 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close with remotes
Yeh, read manual. Do both sensors have led lit. try aligning. you have safety beam problem,
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door opens only 6 inches and stuck
I would try jumping a wire across the white & red terminal to see if your safety sensors are working Properly! If your door opens you have a loose connection or faulty sensors.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
66 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
