Question about Canon Cameras
I have a Canon EFS 18-200mm lens that works perfectly, until I aim the camera down. The zoom slides forward & required an additional hand (if I had 3) to keep it in place. Can you help?
  • margomusic4 Sep 02, 2010
    The zoom on my Canon EFS 18-200mm lens moves/slides out when The camera is facing downward. The previous expert suggested that I have a broken part. Just want to tell you that I know this is a problem with Nikon lenses as well. Just would like to know what others have tried to fix this problem. Someone suggested that I put a thin, wide rubberband on it to add the necessary friction. Any other ideas?
    Both of these suggested solutions are totally off base. There is nothing wrong with the camera lens. I am talking about the external part of the lens. It slides downward when I'm facing the camera downward. I was hoping that someone at your company might have heard of this before and could suggest a "home fix" (since I have done research on this and all lenses in this price range have this problem. If you do not understand or cannot help me, I'd like to end this communication now.
  • Canon Master
  • 17,130 Answers
There is definetly a mechanical failure of the lens hood/zoom movement mechanism.This can be that the gear drive to the motor has come off or broken apart.the camera must be opened to see if this can be rectified or replaced if you have micro tools open to see the zoom mechanism if motor ha jumped from mountings fix it back.Might need to use super glue if plastic mounting have come off.If Idling gears/lense fittings have come off then it might need spares for replacement.Please check this out and commend.Please dont forget to vote.
Posted on Sep 02, 2010
  • Canon Master
  • 4,924 Answers
It is a internal fault in the lens mechanism ..probably something is broke and do not hold it in place ..and this will require the camera to be opened..and cause it is a sensitive operation I will recommend to seek for professional help if you do not want to make it worse..This is not something that you can do it at home ..unless you are good at these thing s..In this case you have to open it ..and replace the lens mechanism ..It is a thing related of a few small levers that operates them
  • Canon Master
  • 3,083 Answers
The lens is going to have an internal broken part (most likely a gear), and will have to be disassembled to be repaired. You might run it by a camera repair shop and see how much it will cost to fix. Get an estimate first, since repair can be costly.
Wish I had better news, and good luck.
Dropped Canon EFS lens now makes clicking sound when zooming in and out
Take it to a repair facility, but it may be expensive
May 26, 2017 | Canon Cameras
I have a Canon EOS 550D camera fitted with a Canon Zoom Lens EF-S 18-200mm lens. I bought both together sometime early in 2010 from London Camera Exchange, Nottingham. I am not in Nottingham at the moment,...
Just a thought - are your Image Stabilizer and Auto Focus switches On or Off?
Might be worth experimenting with them.
Otherwise, sorry, can't help.
May be necessary to contact your vendor.
Aug 09, 2011 | Canon EFS 18200mm f3556 IS Zoom Lens + UV...
I have just purchased a canon eos 600 digital camera.efs 18-135mm lens All excited.\r\nBought it home and on autofocus can't zoom the bird on the dam up very close? I can look through my point and...
Your not doing anything wrong, your Panasonic probably is using digital zoom (which is basically just cropping the picture imitating zoom). Your eyes sees similar to a 50mm lens so your 135mm lens is less then 3x zoom.
Do not be discouraged you will soon learn your cameras strengths and weakness.
Good Luck
Jun 15, 2011 | Canon EOS 60D Digital Camera with 18-200mm...
Hi there, I need accurate draving of EFs 17-85 or is parts list.Wish to order damaged part in side of the lens barel uder rubber ring for zoom to replace it.Is a litle metal electrical contactor with 5 or...
I bought a flex cable from ebay for my efs 17-85mm lens. Maybe you can try ebay and search for flex cable efs 17-85mm (to find similar suppliers) or search for the efs 17-85mm zoom contacts. The part that is broken sends the actual zoom position of the lens to the camera so that a Canon external electronic flash can correctly set its flash zoom position and the exif data is correct.
Mar 23, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Try and fit Canon EFS Lens to EOS 5D Body
As far as I know, you should use L series Lens to fit Full Frame Canon Camera (5D & 1D).
That would be no adapter, but please correct me if I'm wrong.
Jan 13, 2010 | Canon EOS-5D Digital Camera
Distance scale does not move on canon efs 17-85mm lens
Yes, this is normal. Some zoom-lenses adjust the focus when zooming, to always keep the subject in focus. Those tends to be the more expensive lenses.
So you don't have to worry, nothing is wrong with your lens.
/Chris
Jan 10, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Tamron 28-300mm lens
Many zoom lenses of this length, and even shorter have the problem whereby the lens either extends or retracts under its own weight depending on whether the camera is pointing up or down. I had a Canon 28-105mm lens with this problem. More expensive lenses have zoom locks to prevent this from happening. $225 sound like a good price to me!
Sep 28, 2007 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Cameras Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
