Question about Maytag CWE5800A Electric Double Oven
My oven won't heat up. - Maytag CWE5800A Electric Double Oven
  • 262 Answers
You should first check your breaker Box and Flip both polls off then back on and try it.
If both ovens wont work ((Bake & Broil)) after trying the breaker box then the High limit Thermostat could be the problem, It is located in the rear of the machine.
If this problem happened after you did a self clean, most tech's will start at the High Limit Thermostat.
Posted on Sep 02, 2010
Maytag oven won t heat up
the upper element only comes on when you broil or clean with selfcleaner. the bottom comes on when you are baking, it sounds like your bottom element is bad.
May 07, 2014 | Maytag Ovens
Oven won't heat
major electrical problem. call a repair man asap!
May 19, 2013 | GE Profile JT912 Electric Single Oven
I have a Lincoln Impinger pizza oven that won't
Yes, it could be, because the heating element is OK
Mar 22, 2013 | Ovens
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
Jan 19, 2012 | Whirlpool Ovens
My oven stopped heating, and the range element won't turn red when you turn it on but it does have some heat coming from it. What's wrong with it?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 [
Aug 08, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I set the oven at 350 degrees and after 3 hours it has only reached 185 and won't go any higher. The oven is approx. 8 years old.
heatman101
Jul 25, 2011 | Ovens
Maytag CWE5800A Electric Double Oven Logo
175 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
