Question about Hotpoint RVM1435 Microwave Oven
I am trying to find out how many watts my Hotpoint model JES636WK01 has, and I cant seem to find it.
Hotpoint model 6671P convection microwave keeps tripping mains panel Fuse when start is pressed. Could this be a problem with a fuse in the Microwave or is is a dud magnatron? How best to test?
Too many watts on same circuit. Plug it into a different outlet and see what happens, not on same circuit. So one that stays live when micro trips circuit breaker.
Mar 05, 2015 | Hotpoint Microwave Ovens
Jes636wk01
you must read in the back label the specifications of how many Watts, maybe can be .1100watts -to 1800watts or use the formula
P=e voltaje x i anp= watts,
God bless you
Jul 20, 2013 | Hotpoint RVM1435 Microwave Oven
I own a microwave: model # jes636wk01 There is a plastic film covering the wire mess on the inside of the door. Will the microwave operate safely if the film is damaged or removed?
yes. It is there to protect the glass from food splatters It is the panel with the million holes that controls the micro waves I would not remove it but have it replaced if damaged.
Jun 09, 2013 | Microwave Ovens
Getting F3 fault. replaced smart board but did not help. Touch panel?
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jul 22, 2011 | GE XL1800 1100 Watts Microwave Oven
Model jes636wk01 the readout display reads E 1 and none of the buttons work. I press clock and nothing...i press thaw and nothing...I press start and nothing...
This is a common 700Wcounter top oven with no special features, so honestly it will be more economical to replace it rather then repair it.
That said, you probably have a failed keypad.
Jan 18, 2011 | GE Microwave Ovens
I have a new job and I am here alone. There is a
the magnatron has gone bad and needs to be replaced
Sep 17, 2009 | Microwave Ovens
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
I am trying to find the wattage of the Hotpoint Model JES636WKO1. Thanks
According to the owner's manual (page 11) it is 700 watts.
Jan 29, 2009 | General Electric Microwave Oven
Changing the fuse in microwave hotpoint mosel JES636WKo1
This model seems to have a fuse in a cylindrical white nylon fuse holder, probably located near the right rear.
It will also have a thermostat on the magnetron which may be out.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here or here.
Aug 18, 2008 | General Electric Microwave Oven
Hotpoint RVM1435 Microwave Oven Logo
221 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
