Question about Hotpoint NVL333GY Gas Dryer
Hotpoint nvl333gyoww gas dryer's timer stopped working and ran for an extended length of time (about a day). After looking over the dryer, i noticed that during the no heat cycle the timer would work. So I started the regular heat cycle; after five minutes i checked the cycle and found that the dryer was heating the clothes. So, I came back an hour later to find that there was no heat once again. Could you help me identify the problem? Thanks.
  • 262 Answers
The timer : if you use time dry the timer should always move and complete the cycle. if you use auto dry the timer uses a sensor to tell the timer to move. If your not getting any heat your sensor might not tell the timer to move.
So lets start with the no heat problem. First make sure your Vent is clear or just disconnect the vent and put a pair of womans stocking over the end to keep the dust down, This will ensure you do not have a blocked vent. ((( If you have a blocked vent on a gas dryer the safty sensor will shut off the gas valve and you will only get a little bit of heat))) Now try the dryer for small load, ((( if this solved your problem then you have a cloged vent )))
If this did not solve your problem then the coils on your gas valve in the dryer are probably bad.
Posted on Sep 02, 2010
My Whirlpool Inglis Model IED4400SQ0 dryer just stopped. The fuse is fine. I think the problem might be in the start button but I'm not sure. I think this is it because the dryer stopped 2 days ago, then...
this doesn't have a board in it so you either have a bad timer or motor,i would think it would be the timer,try tapping on the timer with a screw driver or something light or wiggle the timer knob and see if it starts,also did you have this on timed dry?it sounds like the timer died and then somehow power went through it again and it ran,the timer controls how long the dryer will run so this is why i think it could be the timer,or a broken wire but try wiggling the knob and see if it starts.let me know thanks.
Dec 22, 2017 | Whirlpool Inglis IP8200 Dryer
Hotpoint nvl333gyoww gas dryer heats for a few minutes, then no heat. Seals appear fine, door latch appears fine, not sure what it could be - suggestions? Thanks.
here are a few reasons that you will get heat for a few min and then no heat.
1. if the vent is cloged, anywhere in the flexable hose to the wall or from the wall to outside. If the vent is cloged the flame in the unit will widen and the thermostat hi limit will shut she burner off untill it cools.
2. The coils for the burner could be bad and will allow the burner to light a couple of cycles and then will get hot and internaly disconect the coil untill it cools down and then will repeat and will get worse over time.
The good news :) The ignitor is good if it lights a flame, If the flame burns for more that 10 sec then the flame switch is mostlikley good. The main valve in most cases will also be good.
Im using Model # NVL333GY0WW
Jan 13, 2010 | Hotpoint NVL333GY Gas Dryer
The timer on my Hotpoint dryer doesn't work
More than likely the timer.  If it works automatic and timed it is definitely the timer.  You can usually find them on ebay with a decent warranty, or depending on how much confidence you have in your mechanical ability take the timer apart, look for the burned contacts, clean them with sandpaper and bend them SLIGHTLY.
Oct 25, 2009 | Hotpoint Dryers
Started dryer at 6 am, got home at 5pm it was still running
if it was set on timed dry replace timer if it was on auto dry check element thumbs up
Aug 12, 2009 | Kenmore 62882 Electric Dryer
I have a Hotpoint WM52 that fills but will not spin / rinse
Check the brushes in the motor, and replace if less than 5mm or or so in length.
Please rate my solution.
Thanks.
Aug 11, 2009 | Hotpoint First Edition WMA12 Front Load...
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Freezer fan running non-stop+freezer icing up
very likely that either the defrost timer is not working or the defrost heater is not working.
May 04, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Hotpoint Aquarius TDL30 tumble dryer timer not advancing
fmw76:
This could be a timer issue or a thermostat.
If you are using a timed dry it would be timer .
If you are using an auto dry cycle it would possibly be a thermostat.
woodychoppers
Nov 01, 2008 | Dryers
Hotpoint NVL333GY Gas Dryer Logo
192 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
