Question about Coleman Powermate Proforce 2500 Generator
My generator runs fine but it wont make electricity I have tried the braker switch I have tried to clean all the connections It just doent make any power I dont know what eles to try
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 55 Answers
These alternators need a slightly magetized armature in order to start. If you accidentally put AC into where it is supposed to come out, you would erase the magnetic field in the armature. You have to get to the excitor winding where you will find a bridged rectifier and apply voltage in that polarity to bring back the residual magnetism. Or if you feel lucky, you can just apply 12v from a battery into the outlet for a second with the engine off. It will magetize the armature, but might be backwards. Shut off engine and try your luck again. Maybe reverse polarity of the battery, and start engine again and check it. Keep trying, till it comes on when you start it. If this never works, you could have a problem with worn brushes.
Posted on Sep 09, 2010
3000w 6.5hp 4 sroke JF168FLH-2 Serial #0612050376
It could be a bad braker or a bad capacitor. Make sure the capacitor is not swelled up out of shape. The capacitor might be in the control box with the braker or you have to remove the rear cover of the generator to find it.
Jul 01, 2014 | Electrical Supplies
Have a EB5000X generator which has staring problems, aprx 8 yrs old and not used a great deal until hurricane Ike came thru here and it ran for several days with minimal down time. Afterwards I changed the...
If I understand the problem correctly, it runs fine after you cleaned the carb, but the auto idle will not engage when you put a load on it. First if it has a switch to turn the auto idle off try that. if it does not rev up, then the magnetic controller is stuck. There is a magnetic coil which is connected to the throttle and this either pulls or releases the throttle when load is applied. My guess is that this is hung up a bit. Look for a small round coil with wires coming off it that is connected to the throttle assembly. You could also try tracing the wire from the auto idle switch backwards. This may just be stuck in the idle position by corrosion. especially if you live in a humid area or one near the ocean. gently try to work it a bit by hand (when the generator is not running) and try a bit of wd40 or the like.
Jan 02, 2011 | Honda Mmd 5000 Watt Electric Start...
Have an Old Circa 1990 Versa in-ground pool heater. Worked fine until this weekend. Haeter wouldn't start so I replaced pressure switch. After replacement still wouldn't start so I shook unit and it...
check all the electrical connections for corrosion. The older millivolt heater run on less than one volt and it's critical that all connections are making good contact. Clean as many of them as you can. You can also try replacing the pilot generator/assy as they lose power over time. Test to make sure output is more than 500mv.
Jun 23, 2010 | Pool & Spa
My kohler generator was running with out a flaw.
Double check your grounds at both the frame and the battery. Otherwise, your starter probably has a shorted field.
Jun 29, 2010 | Electrical Supplies
Portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Mar 16, 2010 | Pramac Electrical Supplies
Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Mar 07, 2010 | Electrical Supplies
NO arc or power on my Welder/Generator
check your back panel fuss and brakers
Oct 11, 2009 | Welding Tools
No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Genrator pops braker
GFI's and motor's don't get along with each other,if the motor is just the slightest bit of any moisture,the GFI will pick it up as a ground...Try to run it without the GFI.
Dec 17, 2008 | Coleman Powermate Powermate 5000W...
Elements wont turn off
i unplugged stove plugged it back up now its got beeping sound not like the alarm my model numberb is13351737wy
May 06, 2008 | Crosley CE35100AA Electric Kitchen Range
Coleman Powermate Proforce 2500 Generator Logo
353 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
