When i plug in the power (the dc in 9v), everything lights up on the screen and no buttons work, pressing the power button does nothing. no music is playing and it's basically not working! please help!
should probably have said they aren't computer speakers! it's just like a little cube thing that you can put the ipod in and plug into the mains!should probably have said they aren't computer speakers! it's just like a little cube thing that you can put the ipod in and plug into the mains!
I am having the same problem, i plugged in the speakers and the front lights up, the time is right, but none of the buttons work. does anyone know how to get it working again?
You can't post conmments that contain an email address.
Contributor
Re: ozaki imini dock
See if you have connected the speaker cable to the right jack i.e the green jack on your pc and raise the volume i the computer if this did not work put some other speakers and play if those speakers works then the problem is with the speakers if even other speakers are not playing then the audio device driver is not instaled on your pc try installing audio drivers which will given to you from *********** board cd if the driver is instaled stil not working it is confirmed that you should buy new speakers or repair it with the product service center
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
It sounds like the DC charging port on the laptop may be damaged, or it may be the power cord...here's how to tell:
First thing....remove the laptop battery, click the battery back onto the laptop and try again. If this doesn't help then read on...
When you put the laptop on the dock, it is getting it's power from the dock connector on the bottom of the laptop. When it is not on the dock, it gets power from your DC adapter. Soooo......take the laptop off the dock and plug the DC adapter into the laptop. Do you see ANY led's light up (on the laptop) when you plug the power cord directly into the laptop? If not, then your DC power adapter for the laptop is probably dead. If you DO see any led's light up when you plug the power cord directly into the laptop but the power button won't turn the laptop on, then the power button on the laptop is the problem.
Take your laptop to an electronics store, and see if they have any universal power adapters for laptops (they come with tips to fit all major laptop brands). Test your laptop at the store with their new power adapter. If this fixes it, then buy the adapter. If this does not fix it, then you should take it to a reputable service shop to get the power button repaired or replaced......or call HP if your laptop is still in warranty.
Hi, Make sure they are connected properly + to + and - to - on both speakers. Make sure they are ohm compatible 4 or 8 ohms not 16 or 24 ohms. Also wattage, If it is less than amp maximum output you can fry them.
1. Fit the DC power and switch on the appliance by pressing the standby button
2. To set time, press CLOCk button to alternate between 12 and 24 hour format.
3. Press and hold CLOCK button until the set hour flashes on display
4. Adjust time using SKIP/SEARCH
5. Press CLOCK to set the time, same procedure for minute
To set alarm
1. Press AL SET 1/OFF 1 button, then press and hold the same button until the alarm time starts flashing
2. Press SKIP/SEARCH to to set time as above
This is easy, hold down "mode" until the alarm time flashes, then press "mode" again, it will cycle through a menu, there is an "on" option to turn on the ipod at a certain time, you select "on" then press mode again, it will cycle to the next menu, set the time you want the ipod to turn on, press menu again, then you can select the "ipod off" time, I keep that option off as I want the ipod to stay on until I turn it off. Now you have set the ipod to turn on at whatever time you want. Turn off that terrible buzzer alarm. The confusing thing is the imini has to different alarm modes, not one alarm mode with two alarm sound options like most everything else.
I have may an adapter as my unit recently stopped working. However, you mention a reset button and I see no such button. I would like to try that first before giving up.
Assume the docking station is powered. I have seen funny behaviour with my docking station. Sure way for it all to work is, everything off, fit to docking station, turn on with power button on docking station. Ensure network cable plugged before this.
My radio was stuck on "scanning media" and the regular reset (volume up and Mode) did not work. Nothing that I did, fixed it... I called Delphi and they said... (1) Put radio in it's cradle, press Volume UP/Mode buttons for 3 seconds until it resets. (2)Then when the "scanning media" message appears press up arrow, down arrow, up arrow.
My delphi screen unlocked. I LOST everything that I had recorded, but that was fine with me.
I had to update the firmware and everything is working fine.
Losing all my recorded songs was much better than having to send in my radio!
Hopefully this will work for you! Delphi was extremely helpful and very nice so don't be afraid to call them if this doesn't work!
I have the same problem with my unit. Emerson customer service made some suggestions, including pulling the 9V battery, disconnecting the phone from phone and power for 3 hours, etc.
Their first suggestion (earlier this morning) was to Push "Up" button and hold for 4 seconds, then pressing the "delete" button three times and re-pressing the "Up" button for 6 seconds.
That procedure failed.
I'm in the midst of the 3 hour wait after full disconnect of phone line and 120V plug.
I don't think my phone will come back. I'll be happy if it does.
Good luck with yours...Richard
