Question about Garmin GPS
I have a etrex Ventury HC GPS. I am trying to download geochaches from the Internet. When I click on Send To My GPS it says to download Comminicator Plugin. I do that and it tells me I have downloaded it successfuly, but when I click on Send To My GPS it tells me it does not detect Communicator Plugin. It also says if unable to run download latest plugin here. I click on that, download it and it tells me I sucessfuly downloaded it. But when I click on Send To My GPS it says it does not detect Communicator Plugin. Any suggestions would be appreciated.
  • 2,272 Answers
If you've installed the Communicator Plugin and the plugin is not detected, you may need to enable the ActiveX control using the blue bar at the top of your browser window.
How can I tell if the Garmin Communicator is installed?A. Go to the Garmin Communicator Test Page and it will tell you if the Garmin Communicator is installed.
The Garmin Communicator Test Page is a great place to visit if you're having any problems. The test page runs a series of test including; Internet browser compatibility, Communicator version check, device detection and communication.
Q. Does the Communicator work on all websites?A. No, the Communicator only works on websites that have implemented it, although it can be added to most any website.
The Communicator is free and supported with an API for all webmasters. If you know a website that would benefit from its use, please direct the webmaster to Garmin Developer.
Q. Does the Communicator work with all Garmin devices?A. No, the Communicator works best with devices that connect to a computer via USB cable.
While some devices that connect to a computer via serial cable or serial-USB adapter will work with the Communicator, they are not officially supported and we cannot guarantee compatibility or provide customer support.
Q. Why won't the Communicator work on my computer or Internet browser?A. The Communicator works on IBM-compatible PCs running Windows XP or later, or Vista operating systems with Internet Explorer 6+ or Firefox 1.5+.
The Communicator also works on Intel-based or PowerPC G3 or later Macs running OS 10.4 or later operating systems with Firefox 2.0+ or Safari 2.0+.
Posted on Sep 02, 2010
Handheld gps just quit.
Go to GARMIN Website and seek help there [from their techys] asap ... ok
Nov 21, 2013 | Garmin eTrex Venture HC GPS Receiver
Webupdater crashed my etrex!!! I did everything they said and it crashed. I need this fixed for my trip up north please help!!!
never use the garmin webupdater, it is unreliable. download the previous version 3.10 firmware from http://www.tramsoft.ch/gps/garmin_etrex-venture-hc-firmware-upgrades_en.html, extract to c:\garmin, plug in your gps via usb, hold the front button in the down position until update process completes, run the updater.exe program and let it complete. You will see an error message at the end of the update process, ignore and let the garmin reboot and it should work again after that.
Jul 30, 2011 | Garmin eTrex Venture HC GPS Receiver
ETrex Venture HC Car GPS Receiver: How do reset unit back to factory spec's...
Hi!
From your owner's manual, to reset to factory defaults (Page 34)
http://www8.garmin.com/manuals/eTrexVenture_OwnersManual.pdf
Select the route page options button and press the Thumb Stick in to access the options menu.
Select "Restore Defaults" and then press in on the Thumb Stick to restore factory settings.
Hope this is of some help to you.
Good Luck!
May 07, 2010 | Garmin eTrex Venture HC GPS Receiver
Garmin Etrex Venture HC will not power up/stay on.
You are not alone it appears. Follow the link below.
Try here.http://www.fixya.com/support/t2084694-gps_stay I had the same problem as you and I followed the advise to do a "bootlock" to download new software via Garmins WebUpdater. http://www8.garmin.com/support/download_details.jsp?id=931
But please note if the unit switches off during update it may cause problems.
Or you could just return to Garmin for a replacement.
Feb 17, 2010 | Garmin eTrex Venture HC GPS Receiver
How do I calibrate my compass in the eTrex Venture HC. The book says to go to the tje menue and then press calibration. My GPS does not give me this option.
I will be happy to help you with this. Unfortunnately, the Etrex Venture does not have an Electronic Compass, therefore you cannot calibrate it. What this means is that this unit will show the correct direction of travel as long as you are moving. The unit takes satellite reading every 1 seconds and compares it's location with the last location. This way it can read the direction of travel. It will not give correct readings unless you are moving.
I hope this helps.
Dec 31, 2009 | Garmin eTrex Venture HC GPS Receiver
My Garmin eTrex Summit HC will not turn on. I
absolutely! Hve yoiu checked that this model does not have a switch on the rear as well as on the front? the one of the front is standby. The other one is main power. Not 100% sure about your model so just check first. Other than that take it back to seller for replacement or instructions
Jun 28, 2009 | Garmin eTrex Summit HC GPS Receiver
My GPS won't stay on
I can solve this by not solving it. First I tried reset the unit to default settings: hold down the power, page, and enter buttons at the same time, a message, "do you really wan to reset..." will appear. Select "yes." If the unit reboots, hurrah. If not, call tech support (1.800.800.1020). Get an RMA, send it back to them for repair. I had purchased mine over 30 days ago but less than 60: Amazon wouldn't replace it, Garmin will either replace or repair. If you want them to send a new unit while the old is in transit, just ask; they will charge and then credit a card once they have the old unit is in hand. Good luck.
Apr 25, 2009 | Garmin eTrex Venture HC GPS Receiver
Need details of internet setting of k220
hello i need the solution to use the garmin etrex legend gps .
Feb 12, 2008 | Garmin eTrex Legend GPS Receiver
GPS Logo
50 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
