Question about Epson Office Equipment & Supplies
I have printer epson tx 121 new model but seems it has general error - remove foreign object, i have check all the corners and dis assembled the even the rail heads, and still it has error - foreign object. it started when i change new cartridge. pls send me ideas of the cause and suggestion!
5 Suggested Answers
  • 80 Answers
SOURCE: my epson stylus t13 have
Hello there,
This is called a false paper jam. normally, a reset is required for this.
Hold the power button for 30 seconds and this should prompt a shut down.
next, make sure that the rollers are clean inside. use a lint free sloth and some distilled water. Dampen the cloth (Q-tips works fine too, please do not use cotton) and rub the rollers.
Then as it dires up. turn the printer on and do a test page.
Please don't forget to leave a feedback and testimony if it works.
Posted on Mar 12, 2011
SOURCE: general error Delete all print jobs and turn the
general error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
Posted on Feb 23, 2010
SOURCE: Remove any foreign objects from
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on.
Posted on Feb 14, 2011
SOURCE: my printer Epson t13 has
do you have a ciss t13 printer?.. coz if you have , then the problem is in your hose installation is short, if its not then your michanichal gear is broke,.. you have to bring it to its service center
Posted on May 24, 2011
General error L200, what is solution? I try to turn off and switch again...It Error again..
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. but not working printer.
Sep 30, 2012 | Epson L200 Original Continuous Ink Tank...
All lights flash on Epson stylus TX110
switch off the main power of printer in running situation and then on the printer.. hope it will be work..
Aug 20, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Epson sylus tx121
tx 121 general error is about service of the printer contact your nearest service centre .
u can also chek you cap assemble(where printhead stop in off position) the lock of cap assembly manualy move can sole your problem
Jan 04, 2012 | Epson Office Equipment & Supplies
General error remove foreign objects inside the printer
Getting General Error Messege delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer
Jun 08, 2011 | Computers & Internet
General error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
Nov 24, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson rx560 general error
Unfortunately a "general error" is different from the commonly assumed "service required" error.
Usually a general error comes about because of something a bit more serious than a paper jam which stops the printhead from moving around as it should, cartridge chips not reading properly, etc...
It's worth trying the following and seeing if any of them help
  • Open the printer lid and using a flashlight/torch, carefully examine the area that the printhead travels along to see if there's any foreign objects, ink soiled paper, etc.. that might be getting in the way.
  • Try getting the printhead off the parking area and check this for any parts of the cleaning station that may have dislodged or other foreign objects that do not belong
  • Remove all the cartridges, clean the chip contacts carefully with a cotton bud and check the contact wires inside the cartridge holder area for any damage.
Beyond that it's a case of looking for clues that might indicate where the problem lies.. ie: if the printhead stops in a particular place, screeching noises, etc...
Hope some of that helps narrow it down some.
Mar 26, 2009 | Epson Stylus RX560 All-In-One InkJet Photo...
My Epson Stylus DX5000 won't work. All the lights are flashing and my comouter tells me to open it up and remove the "foreign" object. I can't see any foreign object and can't see hoe t open it up other...
i had the same problem and checked for paper jam but wasnt any so i kept turning on the printer while looking in side and found that one of the little white cogs where the ink box rests wasnt catching when i pushed it into place the printer set itself and started working maybe you could try this. good luck.
Feb 22, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Both red lights on my printer are blinking
Blinking wit general error message : head carriage error. It cause by head cannot move to parking position or chip at ink tank not good connected. Try to use another chip. Just turn off printer for a moment for clearing epprom.
Nov 09, 2008 | Epson Stylus C83 InkJet Printer
Foreign object
It appears as though the printer hardware itself is malfunctioning and will require service.
Apr 06, 2008 | Epson Stylus CX4800 All-In-One InkJet...
1,693 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
