Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Used wrong power supply .
I pluged in my laptop power supply which is 18volts instead of the maxtor power supply 12 volts. , can thhe unit be fixed by a competent tecki i know
  • havardgjovag Dec 30, 2008
    I had the same problem with my maxtor 750GB barracuda HDD. I were able to replace the burned out component on the HDD`s circuitboard.It took a long time of browsing on the web, and reseach, but the component was clearly burned, and took 2 min to replace.
    Havard
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
If you have used the wrong power supply, the cicuis might be shorted.
If is posible they will solder the bolder & make it work.
I dont recommend it as it will give problems again.
Or
Its just the time to get rid of that.
Be careful in th future.
Good Luck.
Live, Love, Laugh.
Posted on May 10, 2008
Unit powers on but no display and no sound
It sounds like power supply problems which by design supply a multitude of what's called "secondary" voltages which are often different values...18volts, 24 volts, etc. A fuse blown on the primary side (or unit unplugged from wall outlet) kills ALL voltages where-as secondary voltages route through different circuits where some are obviously intact (unit still powering on) but other voltages have failed. It's repair shop time Robert.
Mar 31, 2015 | Audio Players & Recorders
Behringer Powerplay Pro-8 HA8000
Most behringer transformers are 18Volts 1-2 amps to my knowledge, specially in the smaller units. If you are not sure start with reconnecting a 12 volt (AC) external supply and see how you go. Behringer uses (indicated) 17Volts transformers but that is neither here nor there. Good Luck.
Aug 13, 2014 | Behringer HA8000 POWERPLAY PRO-8
Fault Light/ inverter failure
the current from the 12volt supply is not sufficient try a fully charged car battery instead, your inverter needs 30 amps and above of current from 12 volt power supply
Jul 20, 2013 | Televison & Video
Hp computer tower will not go on
Would that be an LED (Light Emitting Diode), blinking on the back of the Power Supply?
If so, instead of being an LED that indicates the Power Supply has power to it, it has now turned into a diagnostic LED (Light), and is telling you the Power Supply is bad.
Do you have an economical multimeter, so I can guide you in testing the 3 low DC Voltages; that come out of the Power Supply?
An economical multimeter can be purchased for as little as $5 to $12.
I have seen them on checkout aisle racks, in major discount stores.
The dangerous high AC voltage, is kept contained within the metal case of the Power Supply.
(100 to 240 Volts depending on what country you are in)
The Power Supply is a Converter.
It converts the high AC voltage into 3 low DC Voltages;
3.3 Volts, 5 Volts, and 12 Volts.
In comparison two D cell flashlight batteries produce 3 Volts DC.
OR;
Use a KNOWN to be good, Compatible power supply; for a temporary test unit.
{"Honey, I'm going to borrow the Power Supply out of your computer.
I'll put it back when I'm done."
"What? I'll be sleeping on the couch? K"} (Lol!)
Also, is the inside of the computer dirty?
(Computer Unplugged from power, Anti-Static Procedures FOLLOWED)
Let's start here......
Also, what is the Product Number?
Back of computer tower, white Service Tag.
P/N = Product Number
Post back in a Comment.
Regards,
joecoolvette
Apr 09, 2013 | HP Pavilion Computers & Internet
Saw your solution for the maxtor 3100 hard drive problem. did you use another maxtor power supply or just a compatible 12 volt?
hi I removed the jack from the maxtor psu and placed it on a 12volt 3amp you can buy these on ebay
Jan 30, 2011 | Computers & Internet
I plugged in a wrong adapter to MT-2 i think 12 v. it should have been 9v now it doesnt work is there any way to fix this problem?
Normally the 12 volt supply would NOT damage the unit UNLESS it had the wrong polarity or was an AC type.
Likely damage if these were used is confined to a few small electronic components where the power copmes into the unit.
Repair the unit before putting correct supply as you could damage the correct supply if those parts failed a certain way.
Aug 01, 2010 | Boss Mt 2 Metal Zone Effects Pedal
Looking for power supply maxtor 3200
You can use any 12 volt power supply for these external drives from any electronics store but you need to make sure they are a 2 amp rating anything under that will burn out your power supply.
You will need to make sure the centre is the + if the supply comes with a selection of plugs.
Hope this helps
Jul 20, 2010 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Acer aspire 3610
Depending on the system and the supplied adaptor type, substituting another can result in damage.
Some adaptors (nearly all 'universal' or adjustable types) are very primative and have little or no regulation meaning that the output set and the output you actually get are highly load dependent and the actual output voltage can be 50% higher than set.
Most laptops use a somewhat better adaptor (more stable output) and have internal final regulation to service the unit's needs and charge the battery pack at the same time.
Using the wrong adaptor can seriously damage the unit's internal regulator and you may have already done that even though the stated voltage is only 3V or some 25% higher.
If the laptop no longer boots, you may have some expensive repairs ahead.
May 13, 2008 | Acer Aspire 3610 Notebook
Maxtor personal Storage 3200 Power Supply [K01PWR3200]
i own the exact same drive. i'm looking for a spare power supply, came across this website, and saw your problem. the power supply is 12 volts dc at 2 amps. the connector that gets plugged into the hard drive: center pin is power (positive) and outer "shield" is ground (negative). hope this helps.
Dec 29, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
82 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
