Question about LG WM2277 XL Front Load Stackable Washing Machine with 7 Washing Programs in 3 Colors ....
HOW I CAN REPLACE THE BEARING BALL IN A LG WM2277H WASHING MACHINE
    Problem Solver:
  • 11 Answers
Http://136.166.4.200/contents/Laundry/WM1832/WM1832xx_Service_Manual.pdf seems to have the manual for a like machine. It does look pretty straight forward removal of the motor, but doesn't go any farther than that. So hopefully common sense in removing any retaining clips and slipping the bearings out withough removing the whole tub/basket assembly.
Posted on Sep 02, 2010
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
How do I replace door latch on LGwm2277h
The service manual for the LGwm2277h can be found at this URL.
http://www.manualslib.com/manual/770130/Lg-Wm2277h.html#manual
The actual step that shows how to replace the latch can be found on page 38 here: http://www.manualslib.com/manual/770130/Lg-Wm2277h.html?page=38#manual
Oct 27, 2014 | LG WM-2277HW Front Load Washer
Hello, my washing machine is making a very loud noise, even louder when spinning?
the drum bearings are bad,it costs anywhere from $400.00 to $900.00 to replace them and possibly more if you need to replace the inner tub with the bearings
Aug 20, 2011 | LG WM2277H Front Load Washer
My washer wm2277h does not have cold water just hot water..Can someone please help me
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 23, 2011 | LG WM2277H Front Load Washer
I have an lg wm2277h washing machine, i keep getting LE error at display how can i fix this?
This is caused by a bad Hall Sensor. when it is bad it tells the computer that there is too much load on the motor, therefore giving you the LE code, otherwise known as a (Locked Rotor Error). It is cheap and fairly easy to replace, the part can be ordered at Sears Parts, using your model number. For information on how to perform your repair, please reply.
Thanks, Repairman45
Dec 20, 2010 | LG WM2277H Front Load Washer
House fuse blew and now there is no power on LG WM2277H washing machine
Did you replace / reset fuse? Turn on washer again if it blows unplug it, unit has a dead short inside.
Dec 15, 2010 | LG WM2277H Front Load Washer
How to Replace Bearing Ball on a LG Front Load Washer??? The bearing ball is leaking water and makes loud noise. need to fix problem please help.
The rear half of the outer wash drum (which contains the rear bearing and tub shaft seal) needs to be replaced. On a 1 - 10 scale, this rates a difficulty rating of about an 8. An experienced appliance tech can do it in about 2 hours, and hit you up for about $500. I do not suggest this as a do it yourself repair. Did you know that the new LG machines use a balance ring to make them much smoother running? (Hint: It may be wiser to replace the machine.)
Jul 04, 2010 | LG WM-0532HW Front Load Washer
How to replace the Bearing Ball on A front load LG Washer? The Bearing Ball on My Front Load LG Washer is Leaking Water and also the tank makes a loud noise while its running. I would like to know how to...
main drum bearing is pressed into the rear outer drum 1/2. you will need to replace that part. hopefully, the motor isn't damaged by the leaking water.
Drum bearing gone on my lg wm-16115fd
I would definitely not attempt this if you have no experience. Is is quite a lengthy process. Specialised tools are required. Discontinue using immediatly, as it will cause further damage to machine and property.
May 03, 2010 | LG WM2277H Front Load Washer
Washing Machines Logo
468 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
