Westinghouse washing machine drain error - Washing Machines
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 10, 2008
I have a Westinghouse LT8195 washing machine,error code is coming up SP ? Do know what this is ? Please help
I think you may have used the wrong kind of detergent or too much.your washer is most likely over SUDs.If you don't use he High Efficiency detergent this will happen. There is a he swirl on the container.shut down you washer for a half hour let it settle. Clear the drain as best you can from suds. if your model has a no spin or low spin use your rinse cycle.you may have to do this again if suds are to thick. Westinghouse has an SD code for SUDs. If you have an owner manual check it.continue to wash normally
Jul 27, 2015 | Westinghouse Washing Machines
I keep getting the error message top-au followed by weird sounds on a westinghouse sensor drive
I tried to research this error but came back with no results. I would contact Westinghouse and talk to their support team.
May 08, 2012 | Westinghouse Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
My westinghouse washing machine LT809s keeps beeping at me and displaying the error code LL?
It means Low Level. Your water level is too low. Your machine isnt filling up properly or the water is being siphoned out as it fills which means your drain is lower than your water level. or your drain does not have an air lock in it any more.
Mar 31, 2011 | Washing Machines
My Westinghouse LT 9555 washing machine won't spin how to fix problem??????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 06, 2010 | Westinghouse Washing Machines
Westinghouse LF708B washing machine wont spin,drains but wont spin Use to work when you thump machine but now wont spin at all
I have found that it is a blockage I manually drain the water through the botton of the machine then the cycle continues as a short term fix. I am not a professional though
Mar 09, 2010 | Westinghouse Washing Machines
I have a Westinghouse mastermind 708 washing machine and it does not spin after wash cycl. i think it might be the pump to pump water out, it still makes a humming noise
I would check the internal coin trap/drain to make sure it is not blocked with socks or 3-in1 dryer sheets. If the water does not drain it backs up and causes error messages and spin problems. These are normally not listed in the manual so you have to take off a panel to find it. Could be at the bottom or in the back. Unscrew and check the trap and remove any blockage. Prepare for a mess if you can't fit a bucket under the trap!
Oct 23, 2009 | Westinghouse Washing Machines
No Drain light flashing on washing machine
ckd for something stuck in pump newer models have a low torque electric pump easily stalled by lint or even tooth pick
Jun 01, 2008 | Westinghouse Washing Machines
Washing Machines Logo
Top Washing Machines Experts
