Question about Pitco Frialator 35CS Deep Fryer
My pitco 35 c the flame is burning yellow and not going inside the very wall i thought it might be the regulator pressure on the fryer on the back side
  • Pitco Frialator Expert
  • 683 Answers
Low gas pressure will produce low flame quality (yellow flame).
Check and remove any dirt or soot on burner holes, and orifice
Burner flame not going inside the fire tube could be due to soot or carbon build up inside the fire tube blocking the flame path, check the inside of the fire tube, if considerable amount of soot is seen, better have them removed.
Yellow flame will cause a lot of problem on fryers if not corrected as soon as possible.
If you have doubt on your gas regulator, better have a qualified service technician to check it.
Posted on Jun 10, 2011
Do I need a preassure regulator on the outside natural gas pipe line coming into my pitco 35+c fryer
I would think so. Check with the gas compan and verify the pressures. Better yet get a professional to do it for you so you do not blow the place up.
Nov 23, 2014 | Pitco Economy 35 lb Capacity 90,000 BTU...
Pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
My Pitco fryer is shooting large flames out of the door. . . . HELP!
Hi there.
You should inspect the fire tubes, it is a tunnel under the fry tank where the burner flames suppose to travel to heat up the oil. Your fire tubes may be clogged with soot or carbon that's why flames cannot go thru the fire tubes. Fire tubes must be free of soot or carbon deposits.
Soot build up on fire tubes can be prevented by keeping the gas pressure at standard as much as possible, low gas pressure produce yellow flame or poor flame quality and in turn will produce soot.
Also, make sure that no air or ventilation is directed towards the flue riser, otherwise, the same will result, flames rolling back towards the door.
Regards.
Aug 05, 2011 | Pitco Frialator 35C Deep Fryer
The flames on our pitco frialator (40lbs) are not suctioning through the tunnels and is burning an orange flame out the front of the burners instead. We are mobile unit with two 100lb tanks. We clean the...
The flame is restricted to flow inside fire tubes, make sure that all fire tubes are free of soot/ carbon deposit. There should be no air flowing (hood fresh air or any ventilation) or entering the flue box because this will cause the flame to roll back to burners. Also, make sure that the unit receives the right amount of gas pressure as specified in the nameplate, this will surely eliminate carbon build up on fire tubes and burners.
May 27, 2011 | Pitco Frialator SG18S Deep Fryer
We have a yellow flames
There are few things which causes fryers to produce yellow flame on burners. First- Low gas pressure and volume, second- carbon or soot formation on burner face and heat tubes. Check first if your fryer has one of these conditions and try to address this as soon as possible.
Apr 29, 2011 | Pitco Frialator Kitchen Appliances -...
FLAMES ARE COMING OUT THE BACK OF MY FRYER,WHAT WOULD BE THE PROBLEM
There may be an excessive carbon deposits inside he heat tubes of your fryer, you have to clean/ remove these carbon to eliminate flames coming out of the back of your fryer (flue riser).Carbon build up on heat tubes are due to low gas pressure and volume; incorrect air and gas mixture.
Apr 17, 2011 | Pitco Frialator SG18S Deep Fryer
Is there an easy way to get access to the rear vent to clean away soot and buildup?
You have to dismantle the back panel to have access in cleaning the flue. Soot formation or carbon build up on fryers are due to low operating gas pressure. When the fryer receives lower than the nameplate rating gas pressure, the flame on burners will be of poor quality (yellow flame) which will in turn produce soot/ carbon.
Jan 30, 2011 | Pitco Frialator 35C Deep Fryer
Long recovery time during busy times have a sg 14s fryer
Make sure you have a nice blue flame in burner the more yellow that it is the less heat it put out. To adjust the flame there are air control slides on the burners there the flame comes out. Open or close them to get the proper setting. You will see the flame go yellow and blue, the bluer the better. The gas pressure could be off which you have to check with a manometer 3 lbs per water column on natural gas and 11 lbs. on l.p. gas. Check the gas valve inlet screen for dirt. If the burner system is operating properly then you have a bad or dirty t-stat
Sep 26, 2008 | Pitco Frialator SG14 Deep Fryer
Pitco Frialator 35CS Deep Fryer Logo
644 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paulcarew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
