Bosch h16 hydropower gas water system
Any idea what costs would be involved. If to high, it is probably better for me to just get a new system (but not the hydropower model)
cheers .. Nick
  • 828 Answers
Cost for both parts and labor vary for one end of the country to the other so I would have no idea what the cost would be in your area.
Posted on May 13, 2008
Need help with Bosch hydropower 13h tankless hot water system
when you turn on the hot water tap there is a pressure switch in the line that sends a signal to a gas solenoid to pass the gas and at the same time to the pizo to start the flame
I would have that pressure switched checked as it may be sticking ( internal contamination) or have dirty corroded points
as gas is involved I would suggest a gas technician do the jib
when you turn off the tap, that pressure switch is shut off so the gas is turned off at the solenoid and the pizo is stopped.
May 21, 2015 | Bosch Water Heaters
Bosch hydropower 13h gas water heater not working
the tank is possibly full of gunk and the thermostat is not sensing the request for hot .flush tank if you can thru the bottom drain a few times if it is bad enough that ou get no water out then only option is to replace with a new unit
I have a instantaneous water system 10H Hydropower ...did not get a manual when installed....I need to have hotter water as it's winter and the water is like warm...not sure what to adjust...opened...
take the cover off the 10 h unit light up the burner by turning on the tap turn the water flow tap on the front of unit (white knob) clock wise slowly feel hot water pipe coming out off unit when temp increases put cover back on check temp at sink if too hot turn knob anti clock wise
May 23, 2011 | Bosch Water Heaters
I have a 16h Bosh hydropower hot water heater . The unit suddenly has no spark .I have taken off the little generater cap and thouroughly cleaned it and the internal turbine . With no improvement . All...
sounds like the generator has packed up. check water flow and clean any filters on the water line. you will need a service agent to check milli volts on generator and power pack
Dec 15, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
Hot water goes cold
Did you find a solution because I am experiencing the same problem, but only since i change to a new shower head?
Regards
Christine
Feb 07, 2010 | Bosch Cooktops
Low Water Pressure Gas System but High Pressure when Solar Water
if you have a gate valve on the unit from the hot water tank it could be as simple as the valve on the gas system being clogged going to that bathroom,, from how it is described it sounds like that would be the problem check to make sure all valve are not stuck in the on position ans change the valve if it is frozen in place
May 22, 2009 | Water Heaters
I have a 2nd hand Bosch HydroPower LPG hot water system and am trying to find a manual. do you have one or is it pretty straighforwward in terms of installation? Mike
I have just dug my manual out (16H) because mine is faulty. email me and I will photocopy it at work this week and email it back to you.
Installation should be pretty straightforward and the manual's not that in depth. There are however some sections on adjusting the gas and the like that you might want to read over.
mchankey at gmail.com
regards
Mark
Dec 04, 2008 | Bosch & Tankless LP Hot Water Heater
Bosch Hydropower 16H instantaneous gas hot water unit not firing??
we had this problem and no plumbers were able to fix it. Finally we got someone from Bosch around and they found part of the ignitor had been installed upside down, since then no problems at all.
Jul 13, 2008 | Heating & Cooling
Our Bosch 16H Hydropower shuts off 30 secs to a minute after heating has started. We have used a variety of settings and only when we have the lower dial on minimum (fully anticlock) and the slider above...
Hi John
The manual is very limited in information it said to check there is
  • high water flow going through your system
  • and check your gas settings is correct!
  • The slide adjustment is your gas flow, which regulates your temperature
  • I have also increase the the gas regulator, which increases the gas flow
I have also been told its not a good idea to have a water saving head on your shower as this restrict the water out put.
Jul 03, 2008 | Heating & Cooling
Heating & Cooling Logo
641 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
